1996 F250 E4od Problems
Old 06-12-2016, 12:31 AM
Larzon's Avatar
Larzon
Larzon is offline
Truck sometimes shifts hard from 1-2 and then sometimes I have to crack crack the throttle to get it to shift. Checked the fluid and it was full. I can get it to shift better if I go 1-2 on the column.
No codes on the trans or the engine. All fluid good. Have an oil leak from the right side of the engine and on the right. Could it be the solenoid pack acting up?
Thanks in advance
Old 06-13-2016, 09:20 AM
knottyrope's Avatar
knottyrope
knottyrope is offline
Does it happen hot or cold?
did you check fluid level when hot?
Old 06-13-2016, 10:20 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
Does it have a chip?
Old 06-13-2016, 11:29 AM
Larzon's Avatar
Larzon
Larzon is offline
Happens more often when it's hot I've noticed. Trans fluid level is good.
Old 06-13-2016, 11:30 AM
Larzon's Avatar
Larzon
Larzon is offline
Yes, TS6. Does it in all levels but I leave it in stock to prevent it from kicking down into 1st
Old 06-13-2016, 02:06 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Maybe like Nick is hinting at, remove the chip and see if it does it.
Da_Lariat_Chariot
04-28-2018 01:32 PM
flainn
10-27-2013 07:50 PM
pikeslyr
04-07-2011 11:01 AM
ELKHUNTN
03-31-2009 09:19 AM
sambo42
10-25-2008 10:34 AM
Quick Reply: 1996 F250 E4od Problems
