Carburetor Adjustment - Ford Truck Enthusiasts Forums
Old 06-11-2016, 07:39 PM
PaleoVo PaleoVo is offline
PaleoVo is starting off with a positive reputation.
Hey everyone! I have a 1956 F100 with a 272Y Block. I am trying to adjust the carburetor, but I can't seem to find anywhere on how to adjust the screws or the idle. Can someone PLEASE point me in the right direction. She runs "great" but she backfires and pops when I let off the fuel. I adjusted the timing although it didn't work unless I left the the vaccuum hose on....so....there it is.
Thanks.
Old 06-11-2016, 10:43 PM
Tedster9's Avatar
Tedster9 Tedster9 is online now
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Do you have the original tea pot carb and loadomatic distributor?
Welcome to FTE btw
Old 06-12-2016, 08:34 AM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
If possible please post a picture of your carburetor and a picture of your distributor. There are many combinations that fit Y blocks and not all work nicely together.
Old 06-12-2016, 05:49 PM
hooler1's Avatar
hooler1 hooler1 is offline
hooler1 is gaining momentum as a positive member of FTE.
I was looking at my 56 shop manual. It talks about an "depopper" valve that was used on the throttle body of the original, dual barrel carburetors. ( I am paraphrasing from the manual now) it was supposed to eliminate the loud popping noise/after fire from the exhaust when the truck is being decelerated with the throttle closed after high speed operation. There is an adjustment procedure for it.But first let's make sure we are talking about the original Carburetor. And make sure your basic adjustments are in order. These would be making sure your timing is set correctly. The manual says for a 272 it should be at 10* before TDC and it is set with the distributor vacuum line removed and plugged. Then check for correct float level to see if you are working with the correct fuel level then setting your idle mixture screws , then your idle speed. Then go back tweak your idle mix screws again and reset idle speed if needed. If you by chance are using an automatic transmission do this while a helper is in the truck in Drive with wheels chocked and applying brakes. There is a procedure on how to adjust the depopper valve. But first let's find out about your carb model and double check your basic adjustments.
1972 F-250 360 motor 2 bbl carburetor problem Donnalee 1967 - 1972 F-100 & Larger F-Series Trucks 11 11-16-2016 06:19 PM
292 Y-Block has never really run right wfon 1961 - 1966 F-100 & Larger F-Series Trucks 10 10-08-2014 07:45 PM
Carburetor Adjustment jjurva 1973 - 1979 F-100 & Larger F-Series Trucks 9 10-26-2011 09:06 PM
Carter carburetor question Dorsai 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 03-07-2011 03:16 PM
Carburetors MikeB 88 Oklahoma Chapter 3 04-28-2009 12:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
