No power at working temperature
#61
Got my new injector installed and motor reassembled this afternoon after work. It took about four cranks of approx. 10 seconds a piece to get it to fire off. Once running it ran like complete crap and scared the hell out of me, after letting it warm up a bit I gave it some throttle and it settled out, it did die a couple times though. I'm attributing that to the fact that I had air tested and I also had an injector that was clearing out the fuel and causing the original problem. Took it for a drive, country roads, up to 50 MPH for about 15 minutes. The longer I drove it the more it settled out.
I do have two concerns though:
1) It seems to be smoking from the exhaust more than it did before. When I give it throttle I actually get some black smoke coming out and it didn't do that before. When sitting at idle in the drive way the exhaust was actually burning my eyes, which it didn't do previously.
2) The turbo whistle does not appear to be consistent. The whistle seems to fluctuate in and out, the tone of it. I hope that makes sense.
If you have any ideas I would appreciate it. I really want to make sure that this thing is done and running correctly. I may just be a little gun shy at this point, but I'm nervous about sending my wife out in it right now. Thanks for all your help everyone. I have attached some photos of my Edge when I was out for the drive.
Approx. 50 miles an hour down flat side road at working temp.
47 MPH flat side road at working temp.
Sitting on road in front of house after drive.
Sitting on road in front of house after drive. (different PIDs)
#62
#63
If it was wet you may have some diesel in the kat and it will take a bit to
clear that out. After air testing they will run like crap. That also happens
if you have the oil rails off. One good way to avoid some of the air in the HPOP
problems is to take the starter solenoid wire and tap it to the + post stud that
the alternator cable bolts to and crank it over 3 times for about 30 seconds with
2 minutes between for cooling of the starter and if you have a charger have that
charging also. One way to keep the FICM happy.
Give it a little more time to see if it clears up.
Sean <BR>
6.0L Tech Folder
Sean <BR>
6.0L Tech Folder
#64
Your "after the drive" Temps tell me either it wasn't long enough drive or you have a bad thermostat. Operating temp is over 186 and you never reached it.
Now, anytime you pump air into the system or have it apart, first you need to allow the engine to warm up. Then on the test drive give it at least 5 Wide Open Throttle runs up to highway speeds. This works out the air in the system, both oil and fuel.
Your IPR & ICP readings @ idle are in spec.
#66
#67
Thanks for all the help guys
Here is the daily update. I took the Ex for a 45 minute drive after work today. It idled a little rough at start up, but settled down after 30 seconds or so. I went on a drive that consisted of backroads and then I-5, a pretty consistent 45-65 mph. After getting the feedback on temps, I would have to agree that the thermostat is faulty and I will be replacing that part this weekend, most likely.
I am still concerned about the smoking though. I laid into it pretty heavy when getting on the freeway about four times. Real white smoke when idling and black smoke when getting on it. I have attached a some pictures, and hopefully a video (yeah, that didn't work, sorry) to get some more feedback.
At a stop light. That is my smoke blowing up past the passenger's side, I had to roll the window up.
After a 45 minute drive at idle. Do these numbers look better or are you still suspecting a faulty thermostat.
I'm pretty sure this is my Cat, I'm not sure how oil in this can cause smoke in my exhaust, but I'm open to ideas.
#68
#70
A bad inject would drip excess fuel into the exhaust its getting hot and burning off
it should start to slow down on the smoking
Why do you say oil was the down pipe showing Oil in it when separated from turbo??
Fuel mixed with Diesel soot will look like oil
It might be the case there is another bad injector if the bubble test isn't don't correct or in a way each cylinder is singled out and you have 2 bad inject one could be missed for the sake of being thuro I pull all glow plugs on the bad side and reinstall one GP at a time repeat bubble test then pull the GP out before moving to the next cylinder
#71
I will perform this test this weekend.
#72
the Oil is getting Hot and burning off inside the Cat causing smoke
BUT I think its Fuel in there from bad inject However turbo problems can leak oil into exhaust pipe so if indeed it is oil you have another issue
the way you describe the smoke it sounds like another bad inject but it could just be burning it off from the bad inject thet you just replaced
#73
IMO if it was RAW Fuel burning off in the exhaust I would expect it to burn off as Black/grey smoke maybe even white whatever color it should be more consistent of a color and NOT Change color per throttle position like it did with the bad inject
you posted that your still seeing white smoke at Idle and Black smoke at WOT what is Classic Failed inject symptom
Id repeat bubble test again
when I went thru this a month ago I did the bubble test and tested Each cylinder individually found and replace the Bad inject
After the inject was replaced before I buttoned the engine up I did another bubble test to make sure it passed and it did so put everything together and all was Good
When mine went I replaced the bad inject within 5-10 miles of it going bad ( as soon as I saw smoke) Truck was pulled out of service Immediately
One of the problems if a bad inject gets ran and pumps compression gas into fuel rail is it will KILL other inject in that side
If you fail a Bubble test again consider replacing the other 3 inject that side
And if it passes we can trouble shoot other systems if smoke continues after giving it a day or two to burn off any excess fuel what the bad inject dumped into exhaust system
#74
#75
