Ford 390 intake manifold hardware
What's the general consensus on the hardware for the intake manifold? I installed mine with hex cap screws and just using silicone under the heads and torquing them to spec. Wasent this what they came with from the factory? I didn't know if I needed a washer or lock washer
No washers needed for the bolts - just install and torque in sequence and to specs. I'm presupposing when you say, "Silicon under the heads" you mean the bolt heads? ( A little confused here, at first). If you feel it's needed, do it - can't hurt. Just be sure to re-torque the bolts after a few hours of running....the silicon might have become useless under torque and heat.
I don't believe FE motors came from the factory with sealant under the intake bolt heads.
I coated the bolts with Teflon paste, because I believe that some of the bolts pass through the water jacket. I installed an Edelbrock RPM manifold. I used arp bolts which came with washers, so I used them. I did have to shorten some of the bolts, because the Edelbrock is thinner in some areas.
skuteman
01-08-2005 04:02 AM
sejackson
07-02-2004 09:46 AM
