Power running boards - intermittent from 1 door only
If I open the rear passenger door first, the running board does nothing. Once I open the front passenger door, the passenger running board works as expected.
I can open/shut the front door - let the running board close, and the rear passenger door will operate the board correctly.
Thoughts?
Thoughts?
Anybody? It appears to be getting somewhat worse. Now It doesn't reliably come down with the front door either. I can open/shut the front door repeatedly, and maybe on the 5th time it'll come down. Other times it's the first try.
And still, once it comes down once with 1 door, it works fine with both on that side for some time
You have to pull off your door panel. Unbolt your inside door latch to check and see if your door ajar sensor is either still attached to the latch or broken. If it is not broken push in on the sensor to see if your running board comes down. If it does then you might just have a loose connection or the sensor is dirty. Hopefully you don't have to drop your running board to clean the contacts inside the running board motor. You can find videos on YouTube under replacing door ajar sensor. I hope this will work for you like it did for me.
Thoughts?
Thoughts?
Going to try to check the door ajar sensor on the front passenger door.
rockscout
1983 - 2012 Ranger & B-Series
04-17-2017 08:38 AM
surveyguy
1999 to 2016 Super Duty
09-03-2009 10:29 PM
