Is There A Part Number for this ?
If you're talking about bypassing the fusible link, don't do it. That link is there for a reason.
UPDATE---did a temp splice job on the wires , did another amp test with the Neg cable unhooked, no draw, tested the Alternator posts, got the following results
STA---12.4
FLD---7.5
BAT---14.1...then checked the amps at the other end of this wire, at the Fusible Link end, 0 so I think the Fusible Link is bad ? and can it be purchased at a parts store ?
STA---12.4
FLD---7.5
OK...so after all I did yesterday, I go out this morning to use my truck, and nothing, but dome light was on, so I got my meter out and I'm reading 9.5 Volts...so it appears I've slowed down my drain, because before it was flat out dead after sitting over night, just need to figure out what it is ...could the Voltage Regulator be the culprit ?
It's possible, charge the battery up and unplug the regulator. Let it sit overnight and see what happens. I would check the alternator first though. If a diode shorts, the alternator will still put out but the shorted diode will drain the battery overnight too.
No. The difference between full charge (12.eight) and Dead, is less than a single volt.
9.5 is shorted cell territory. Best to never let a battery get that low. Charge it up for a couple days at a low rate and let it cook for a while. Auto start batteries will be ruined quick by deep discharge like that.
Disconnect all the wires, leave the alternator installed on the truck try lightly touching the "BAT" wire to the "BAT" terminal, look for a spark. There should be no spark. If there is, the alternator is shorted internally.
