351m to 460 swap?
Old 06-13-2016, 01:41 PM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
I'm not certain.
The 460 crankshaft sticks out 1/2" more than the 351M/400 crank in relation to the bellhousing face.
There may be a different flexplate or TC to account for this.
For certain the ring gear needs to be where it needs to be for the starter to engage.
I'm not too well versed in automatics when it comes to this swap.
Hopefully somebody else will chime in.
Old 06-15-2016, 10:27 PM
82F100SWB's Avatar
82F100SWB
82F100SWB is offline
The longer crank stickout is only on the external balance engines. Internal balanced with a 390 flywheel and a M/400 bell will work just fine.
I know there is no change in the transmission for an auto. The flexplate of course is a different part, but I am not sure if anything changes besides the balance weight.
Old 06-15-2016, 10:35 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Its an '85 460 so definitely external balance.
Idk how Ford made the same starter work if the flywheel/flexplate moved that much during the '79 changeover, but it's good to know.
Old 06-15-2016, 10:37 PM
fordtrucksforever's Avatar
fordtrucksforever
fordtrucksforever is offline
Originally Posted by BigCountry1978
got a 1981 f350 2wd with a 351m 4 speed, and i have a built 460 that was pulled out of a 1985 4wd 4 speed, what all would i need for this swap? i know the bellhousings should be the same, and i have the 460 flywheel, i just need to get a new 460 clutch. other than that, engine mounts, what else would i need and how easy would this swap be. i still have the 1985 4wd 4 speed too.
If I understand the above, you have the 460 and 351M motors and trans. I guess that includes the 460 bellhousing still attached?
Use all of the 460 flywheel, clutch, bellhousing, and bolt 351m trans to it. Then convert over to the hydraulic clutch assembly. Or am I still missing something?
Old 06-16-2016, 07:05 AM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
There's ~1/2" of difference between the flywheel position for an M and a 460. What we don't know is how Ford accommodated that change. Was it all in the bell housing, all in the input shaft, or some in both?
But, if the OP has both setups he can measure the bell housings and input shafts and figure it out.
Old 06-17-2016, 02:26 PM
82F100SWB's Avatar
82F100SWB
There is no change in the input shaft. The 460's bell is deeper to accommodate the crank stickout and larger diameter flywheel.
Old 06-17-2016, 02:54 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Right
.... so what happens when you try to use a shallow 351M bell on a 460????
The input shaft bottoms in the pilot bearing, the pressure plate & flywheel hit inside the bellhousing.
...and there's no room for the release arm.
THIS is why L&L make a swap flywheel and clutch.
(Posts 2, 6, 7 &12)
What's so hard to understand?
Old 06-17-2016, 03:18 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Agreed. The catalog shows that all NP435's took the same input shaft regardless of the engine, both 6 and 8 cylinder. It is listed as "17 helical—2 1 clutch teeth— 10 splines-9" long", So the difference is in the bell housing.
Old 06-18-2016, 06:18 PM
ef150owner's Avatar
ef150owner
ef150owner is offline
460 swap
Years ago I swapped out my 5.8HO from a 86 f-150 and bought a 69 429 with a heavy duty C6/ case from a station wagon and bought a .010- .010 460 crank for the complete rebuild. Used DOVE ported heads and 1.75- 2.25 stainless valves.
I got all my conversion parts from L&L products to fit all my 351 accessories to the 460. Included were a new rear sump pan, Military grade HD motor mounts, Doug Thorley Nickle plated HD tri y headers all the cad plated brackets for P/S pump, AC mount, alternator mount, a nice remote oil filter set-up and a few things I can't remember cuz it was over 15 years ago.
I DO remember the total package back then was well over a thousand plus bucks.
Soooooo, how bad do you want that high torqin' engine? I would have been better off to get new heads and cam etc for the 351 HO and been happy with that, especially the gas mileage.
The bored out 460 will pass anything on the road but a gas station!
Just my 2 cents.
Bud in Winslow AZ
Old 02-04-2020, 03:53 PM
Bdreamin's Avatar
Bdreamin
Bdreamin is offline
Originally Posted by ArdWrknTrk
The bellhousings are NOT the same. Only the bolt pattern is, which is fine for a C6.
460's didn't have a manual option until 1983.
And I dont think the 460 clutch is going to fit inside the shallower 351M mechanical release bell.
And in order to use the 460 tranny/bell you need a hydraulic clutch pedal assembly, which doesn't fit pre '83 cabs.
This is why L&L makes a dedicated swap clutch and flywheel.
Make sure you get the radiator and exhaust system from the donor as well.
ford put 460 with 4 speeds in 79 rord truck and 77 have both with original equipment the piviot ball for the z bar on the 79 460 bolts to the bellhousing and the one for the frame is easy to make or order and pre 83 ford cab can have all the clutch petal parts needed to useanual clutch the 400 bell housing will work with a 460 done the 400 460 swap several times use a 174 tooth fly wheel and diapham clutch we have 2 pulling truck with 460 and manual trans
Old 02-04-2020, 06:42 PM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,654 Likes on 1,337 Posts
Only 2wd correct? The 4x4 trucks in the late 70's only got the 400? Which would not matter with the bellhousing.
ManfredVonRichtofen
1978 - 1996 Big Bronco
01-08-2014 09:50 AM
Kirbys73F100
22
11-03-2009 11:04 PM
roger dowty
04-19-2009 10:56 AM
jrwhitey_2000
01-09-2009 07:51 PM
rye2842
06-07-2007 08:30 AM
Quick Reply: 351m to 460 swap?
