Twin HD Alternators
The combination of supplemental heater, snow plow pkg, and upfitters requires the dual alternators. However, it appears there are "dual heavy duty" alternators which is one step above "dual alternators" which gives you one standard and one heavy duty alternator. Some other packages may require it as well. I noticed this bump on my order.
I like the idea of more power, but obviously there is a slight fuel economy and power reduction with more drag on the engine.
I would hope they would be the same thing. Like the idiots who design different size windshield wipers. Come-on, geeez. Have some pity on the owners.....I need an alternator. Uhh the one on the left....the vin # above or below what?.....The mounting hole is on the left.....No the connector doesn't match.....Like Chevy with starters for the 350: 3 bolt, 4 bolt flange to the left, flange to the right, solenoid on board, no solenoid but special contacts, oh you wanted the two bolt one. We don't have any but try Pontiac (RIP) down the street. They might have one which will match.
Well, based upon the order guide, here is what I come up with: the extra heavy duty alternator on the 6.7L is 220A. The standard alternator is 157A. Added together is the 377A which is your rated output. Make sense now?
I am curious if there will ever be a draw of 377 amps. Even fully discharged batteries do not take full amperage from the alternator. I know my camper can only draw 30 amps on its charging circuit limited by the truck distribution/fuse panel. Not much when the batteries are low after a week of cloudy weather off grid.
The important point to remember is that an alternator can only generate that amperage during ideal temperature and RPM conditions. So during very hot conditions and idling, 377A might be half of that.
The headlights are not dim during glow plug operation on my 2016. In cold weather, not only are the GPs running but also the urea tank and lines are being heated, along with heated seats, supplemental heat, heated rear window, heated mirrors, headlamps, fog lamps, trailer lights / batt / brakes, and audio system.
Good catch Rasalas....I bet that's it...I just looked in the guide also and it does not have an "s" on the end....So I believe Troverman is correct with the combination of output with one regular and one heavy duty to give you the "Dual Extra Heavy Duty Alternator" option.... 67B in the guide.
I like the dual alternators too.
#28
#29
