1978 F150 with a 3speed Toploader
Hi guys,
Yesterday I was driving my truck and all of a sudden, I could not press down on the clutch pedal. I could only press about half way and could not shift into any gears. No matter how hard I tried I could not engage the clutch to shift into any gear. Luckily, I was able to pull over. I looked underneath the truck and did not see any loose bolts in the shift linkage that attaches to the side of the toploader, no loose bolts in the bell housing, I also made sure that the equalizer bar was not loose. The clutch release rod was not broken or damaged, and it was making contact with the clutch fork. I was thinking that maybe I need to do an adjustments on the release rod but the two jam nuts are adjusted as far as they can. When I tried to adjust the jam nuts, it caused the clutch pedal to fall straight to the ground and not come up. I reverted the adjustment on the release rod back to what it was originally. The only thing I noticed that was odd was that there were two bolts under the clutch fork that have two nuts that were semi loose. These bolts are part of the clip where the clutch fork rests on. The clutch, pressure plate and flywheel are only 3 months old. I got them new from NAPA so I'm positive it's not the clutch. I think somewhere an adjustment needs to be made but don't know where. I have attached some pictures of how the components were originally. I noticed some transmission fluid where the transmission connects to the driveshaft and also one the speedometer.
1978 F150 with RUG SR-OD Single Rail 4 Speed Overdrive
Hi guys,
Here's the SR-OD's shift lever parts.
Yes sir. I have a 302. I believe those pictures you posted are from the Ford shop manual. I have that same manual. I was reading in the manual about how to adjust the clutch release rod and it mentioned that both the jam nuts are to make contact with each other. However in the pictures I posted the jam nuts are separated by the equalizer bar. This is how my adjustments has always been but I wonder if its wrong.
Clutch fork pivot torque specs?
I think I may have pinpointed the issue. I noticed that the bolts on the clutch fork pivot were loose. I tried to tighten them but I noticed that it was never going to tighten. When I removed them I saw the threads were stripped. So I bought some high grade bolts, nuts and lock washers. I also put some blue loctite on the bolts.
I have replaced the new bolts onto the pivot but was wondering if anyone knew torque specs? I'm guessing it's no more than 15-20 ft/lbs.
I put a picture of the old bolts and the location I am speaking of.
WhodatPat
05-23-2009 08:28 PM
Young_unn
06-20-2006 07:45 AM
82F100SWB
10-24-2002 11:51 AM
