I just changed the oil for the first time on my truck. The owners book says 5 quarts of oil. I poured in the 5 and checked the oil and the oil just comes to the "add a quart mark" on the dipstick. So does it take 6 or 5? The dipstick is seated properly down it there... Got a Motorcraft FL-1A filter....Any ideas?
My '94 takes six to get to the full mark, but leaks down rather quickly to the add mark and stays there. Running a quart low has no bad effects and a cleaner driveway. No noises and I still have 40-60psi of pressure.
The book isn't wrong, it's correct, just a little misleading. The engine takes 5, the filter takes 1 so put in 6 and it'll come up to the line properly.
I had the same dillema. Ford said 5 but Chiltons said 6. It takes 6. Off stang's last post, who changes the oil and not the filter? Thats just dumb if you don't.
Originally posted by MustangGT221 The book isn't wrong, it's correct, just a little misleading. The engine takes 5, the filter takes 1 so put in 6 and it'll come up to the line properly.
