50 F1 firewall insulation pad
Old 06-09-2016, 10:04 AM
3twinridges's Avatar
3twinridges
3twinridges is offline
My firewall insulation (I think its original) is flaking at the bottom. Does anyone know if the original style is reproduced or available from anyone. I am leery of the ABS plastic type.
Jonathan
Old 06-09-2016, 10:34 AM
Mixer man's Avatar
Mixer man
Mixer man is offline
I have a new ABS firewall pad and it fits perfect, and looks great. The only thing I think to be leery about is that it won't satisfy the purist.
Old 06-09-2016, 10:39 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
I made my own with pond liner, 45 mil thick. It's really cheap and easy to work with. Because of some non-standard stuff I didn't want to buy ABS and have to cut it. I put carpet insulation on the firewall first. Total cost under $50. Easy to clean.
Old 06-09-2016, 07:51 PM
1950FordF1's Avatar
1950FordF1
1950FordF1 is offline
Great idea Ross. I've been stewing over how to cover my firewall. Are those the original style spring push-in clips?
Old 06-09-2016, 07:57 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Yes, they work great
Old 06-09-2016, 09:48 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3
Scotty's 52 F3 is offline
Dumb question, how do the buttons come off? My original was almost turned to dust and fell right off. I still have the clips/buttons in place. Are they reusable?
Old 06-09-2016, 09:53 PM
abe's Avatar
abe
abe is offline
One Meadow Green Owner
Received 2,615 Likes on 1,456 Posts
I am not sure if they can be reused. If I remember correctly I tried but they didn't grip so well. I bought an ABS pad and also bought new push in clips.
Ross, your homemade pad looks great!
Old 06-09-2016, 10:02 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I just squeezed the clips on their shanks and pushed out from the engine side. Some were broken or destroyed in the process. They are supposed to be re-useable. I used Christmas trees to make up for the broken ones, they actually work well but I used them where they are out of sight.
Old 06-09-2016, 10:06 PM
Scotty's 52 F3
Thanks, I'll have to take a closer look at them and see if I can salvage any.
Old 06-09-2016, 10:19 PM
Cobwebman's Avatar
Cobwebman
Cobwebman is offline
How hard was it to mold the pond liner into place?
Old 06-09-2016, 10:32 PM
3twinridges
Good thread...I don't think originals are around, even Mr Selzam has not seen one.
May just keep mine for a while. When I do a radiator flush and clean the heater core I may look at the abs piece from DC. DC also has a black fiberglass option also but the parts resource seemed to think the abs version mimicked the original better.
JB
Old 06-09-2016, 11:18 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The pond liner is very flexible. I didn't do any pie-cuts or anything to fit it around the center hump in the firewall.
The original pad was, as far as I could tell, asphalt-impregnated paper over corrugated cardboard. When I pulled mine out (in many pieces) I was shocked how much oil it had absorbed thru the many unused holes in the firewall. If ever a good spark hit it, it would have gone up like a candle.
Old 06-10-2016, 06:17 AM
GreatNorthWoods's Avatar
GreatNorthWoods
GreatNorthWoods is offline
No reason to be leery of the ABS type. I used one in my 49 and it worked great...
Old 06-10-2016, 08:28 AM
abe's Avatar
abe
abe is offline
I think you can buy the ABS without any holes in it. Check Mid Fifty.
Old 06-10-2016, 09:39 AM
toby tough's Avatar
toby tough
toby tough is offline
Christmas trees? Are those the plastic bits with the ribs on the shaft so to speak?
Quick Reply: 50 F1 firewall insulation pad
