Auto 4WD
All the early pictures show three positions. Just like all the current ratings are placeholders. You don't think Ford has the ability to hide something until release? The trucks you are seeing in press photos are "pre-production and subject to change"... But who knows, maybe it's all a mistake. Guess we'll have to wait and see.
You could, but there wouldn't be any real benefit in the rain. In patchy snow would be good. It's just the same as 4 High, but it allows some slip to prevent damage. It's not the same as AWD.
First off, we can't confirm if the new Super Duty actually has 4A or not.
However, if it does, there are many, many variations to 4A. Some literally use the ABS sensors to detect the rear wheels spinning and the front wheels not; thereby engaging the electrically shifted transfer case. Clunky and slow, and can cause binding during turns. Some are much better, using a multi-plate clutch between the front shaft and front shaft output in the transfer case. This can instantly add and remove power to the front. Very similar to the 2017 Raptor system...but can also be locked in as needed. Other systems include a full center differential with an electric lock as "4-Hi / 4-Low."
You can leave 4A engaged year round. On a Super Duty with locking hubs, it would seem the hubs would need to be engaged at all times 4A is selected in order to be effective. However, this would impact gas mileage by maybe 1mpg.
We will have to wait and see. A true AWD vehicle like an Audi, Subaru, Range Rover, etc simply never slips. They use a center differential and it is very effective for rapidly changing conditions as well as snowy / slippery / off road driving. Our pickups have always been part-time 4x4, so either engaged or not. Lots of times in changing conditions 4x4 is inappropriate or only needed briefly. AWD would be nice.
Yeah there are lots of ways to do 4x4/AWD with various t-case and PTU setups, but I was explaining how it works in the regular F150, Silverado 1500, and Ram 1500. Yep, the Raptor will be getting a different version. I would love a 4A that works like Ford's Intelligent 4x4 system, which is similar to how it works in a Jeep Rengade, Chrysler 300, and Dodge Charger. That is driving in 2wd until torque is needed to be sent to the opposite axle for added traction. Just can't see it happening. I would be surprised to see any 4A setting on a Super Duty, but hope I am wrong. If it does, I would bet money it will be the simpler design that I mentioned previously, where the t-case sends a constant 50/50 torque split to the front and rear, t-case also allowing slip (acting as a center differential, without it actually having one).
I agree if the Super Duty comes with a 4A (which would also surprise me if it did at all) will be a simpler system. I disagree that 4A would supply power to the front and wheel all the time...I think it would be more like the GM design where the electric motor rapidly engages and disengages when ABS detects slippage of the wheels.
Have you had a chance to try out the power display in a current F150? I can't remember Ford's name for it, but you can see the torque transfer as you accelerate. In 2H it shows the rear wheels lighting up, in 4H and 4A it does exactly the same thing: All 4 wheels light up as you apply throttle. The Expedition has the ABS system you are talking about. I don't think it changes anything from front-to-rear transfer, but rather improves traction from left-to-right in place of a mechanical locker or limited slip differential. If the left wheel has almost no traction, it will apply braking to that wheel so that torque is transferred to the right wheel. I believe the transfer case in the Expedition is the same as the F150, just sending the 50/50 torque split in 4A and 4H.
I'm not sure how much the power flow screen can be trusted with the 4A. Ford would like you to think 4A = AWD but it really does not.
Have not looked at the power flow screen in 4WD because it is summer right now.
If they were adding a all wheel drive feature to the super duty it would be highlighted in the new product features in the order guide. Ford is not going to hide this feature it's not that revolutionary. Maybe it comes on the platinum? But I honestly think it's just a mistake and they'll be no A4 option on the superduty.
#28
#29
#30
I am leaning towards this logic too. Makes perfect sense that they would have it in the order guide if it was true.
