534 Rotating assembly
The engine side of the clutch housing I'd unique yes, but the trans side is too? So there is such a thing as a Ford pattern Allison 545.
The Trans Side is non ford, or OEM standard. There are Allison Bellhousings available online if you search. There was one on Ebay and Commercial Truck recyclers usually have them in stock. Finding a good torque converter, not sure about that though.
https://truckpartsinventory.com/flyw...ford-534-parts
Hi Nolan, was running a spicer 6352 but will be using a spicer 5756B. I don't have the numbers handy, but I can look them up when I find some time. Ford 1958 59 HD Truck Distributor 401 477 534 CID V8 B9TF 12127 A | eBay
The Water Pump Housing p/n is c1te-8503-a.
Yes, same as Y-Blocks, FE's & so. Ford Pickup Truck Distributor Cap - V8
I'm running Pertronix & it's work great.
Although I have no personal experience with this engine, what I can tell you is, the ONLY way to change the stroke dimensions on any engine, is to change and/or modify the crankshaft throw (throw = 1/2 stroke). Changing pistons or rods do NOTHING to change the distance the piston travels from TDC to BDC.
The following users liked this post:
Welcome to FTE.
The only "performance" SD motors were turbo'd motors in boats.
There are a number of things that would limit a performance build. The plank head and resultant combustion chamber situation, the weight and strength of the rotating assembly, and the fact that there is no aftermarket support. Add to that the size and weight making it an impractical swap into any smaller vehicle, and you are past your 3 strikes.
If you must, read on:
https://www.ford-trucks.com/forums/7...g-a-534-a.html
https://www.ford-trucks.com/forums/4...emensions.html
https://www.ford-trucks.com/forums/2...tatistics.html
#29
#30
DJdemon6696
09-09-2008 11:41 PM
cbfomoco
10-24-2005 03:44 PM
Rat wagon
15
02-21-2003 01:09 PM
