534 Rotating assembly
Best I can find, the crank and pistons are different. See post 58 here:
https://www.ford-trucks.com/forums/4...ne-else-4.html
Is this for your bus?
Easy for me to say, but if you are going to repower, go with an oil burner.
The 534 is going to be really hard to find parts for, and if you have a 477 you want to convert, I think you are going to by buying a complete 534 to get the parts.
Not for the Bus, but not not for it either. If I use the bus as a toy before I get around to camperizing maybe, but if I use the Bus for actual camping, it's getting a Diesel for sure and at that point I would probably go Detroit.. 4 or 6-71. Maybe 6v53 if it isn't too wide and hide the turbos under the floor. This engine would be a conversation piece, and only because I haven't laid my hands on a 549 Binder yet.
The following users liked this post:
Why not? If you're going to build one of these things, I suppose you will do your measuring and figuring with the actual engine. AFAIK that's the only way you will be able to figure out what you want and have it made.
There were turbo units for these when they were put in boats, but I think that was it for performance stuff.
Finding 534 pistons in a full set is difficult at best. Since the plank head is 60 degrees in relation to the 90 degree bore, relieved domed pistons could be made in fit into the 30 degree combustion chamber which is actually contained within the cylinder. Finding someone to design, & do R&D would be very pricey. Better way to go since the engine is very robust and low compression is to turbo charge it, goggle Seamaster 534ti.
Bell
Is this your engine? Looks good. I'm wondering about the size of the bell. Are they all SAE 2?
Well I suppose it's not zero deck in the traditional sense since the piston is at a different angle than the deck. I guess zero deck would be at the edge where the piston actually meets the block deck.
