534 Rotating assembly
Old 06-28-2016, 01:50 PM
Nolan Harris's Avatar
Nolan Harris
Nolan Harris is offline
Originally Posted by 57 M600
believe most SD Engines had Ford supplied Bell/Clutch housings which are unique & not SAE patterns. This info is not supplied in Spicer manuals for casting #'s supplied to Ford.
The engine side of the clutch housing I'd unique yes, but the trans side is too? So there is such a thing as a Ford pattern Allison 545.
Old 06-28-2016, 02:26 PM
57 M600's Avatar
57 M600
57 M600 is offline
The Trans Side is non ford, or OEM standard. There are Allison Bellhousings available online if you search. There was one on Ebay and Commercial Truck recyclers usually have them in stock. Finding a good torque converter, not sure about that though.
https://truckpartsinventory.com/flyw...ford-534-parts
Old 06-28-2016, 02:52 PM
Nolan Harris
SAE
So it is SAE. I was thrown by the wording in that other post. So the transmission is the easy part
Old 06-28-2016, 02:59 PM
57 M600's Avatar
57 M600
57 M600 is offline
The transmission is easy, getting the 534 housing to match is the trick. The only SAE 534 blocks were specifically cast for stationary applications (I believe). My engine is not SAE, it's more like a bigger crossbreed of a Y-Block & FE.
Old 06-28-2016, 04:30 PM
Nolan Harris
SO, this bell, with the SD pattern on the engine side and the round Trans pattern on the trans side is not necessarily SAE?
Old 06-28-2016, 04:53 PM
57 M600's Avatar
57 M600
57 M600 is offline
The trans side should be or likely is SAE, the block side is likely a Ford pattern.
Old 06-28-2016, 05:48 PM
Nolan Harris
Clutch
Do you have clutch part numbers? What sort of transmission are you running? I've been talking to the guys at Phoenix about an adapter to run an automotive transmission. By the way, do you have any extra goodies. I need a few things. ( Water pump housing and distributor)
Old 06-28-2016, 06:00 PM
57 M600's Avatar
57 M600
57 M600 is offline
Hi Nolan, was running a spicer 6352 but will be using a spicer 5756B. I don't have the numbers handy, but I can look them up when I find some time. Ford 1958 59 HD Truck Distributor 401 477 534 CID V8 B9TF 12127 A | eBay
The Water Pump Housing p/n is c1te-8503-a.
Old 06-28-2016, 06:07 PM
Nolan Harris
Sweet. Is the cap and rotor same as anything else?
Old 06-28-2016, 06:23 PM
57 M600's Avatar
57 M600
57 M600 is offline
Yes, same as Y-Blocks, FE's & so. Ford Pickup Truck Distributor Cap - V8
I'm running Pertronix & it's work great.
Old 06-30-2016, 10:02 AM
m-chan68's Avatar
m-chan68
m-chan68 is offline
The difference between the 477 & 534 is only the pin location in the 534 piston (compression height) which changes stroke length. The rest of the rotating assy is the same.
Although I have no personal experience with this engine, what I can tell you is, the ONLY way to change the stroke dimensions on any engine, is to change and/or modify the crankshaft throw (throw = 1/2 stroke). Changing pistons or rods do NOTHING to change the distance the piston travels from TDC to BDC.
The following users liked this post:
Old 10-03-2016, 12:06 AM
240zgt's Avatar
240zgt
240zgt is offline
Specs
Im interested in fooling around with the specs on this engine and seeing what it would take to make it a performance engine. Does anyone have a source for a decent set of specs for this series? Bore, bore spacing, stroke, valve size, that kind of stuff.
  #28
Old 10-03-2016, 11:05 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,591 Likes on 1,296 Posts
Welcome to FTE.
The only "performance" SD motors were turbo'd motors in boats.
There are a number of things that would limit a performance build. The plank head and resultant combustion chamber situation, the weight and strength of the rotating assembly, and the fact that there is no aftermarket support. Add to that the size and weight making it an impractical swap into any smaller vehicle, and you are past your 3 strikes.
If you must, read on:
https://www.ford-trucks.com/forums/7...g-a-534-a.html
https://www.ford-trucks.com/forums/4...emensions.html
https://www.ford-trucks.com/forums/2...tatistics.html
  #29
Old 09-17-2023, 03:40 PM
Bloodviking's Avatar
Bloodviking
Bloodviking is offline
1st Gear
Wrong info
Originally Posted by Nolan Harris
So I'm just a set of Pistons away. Maybe get some extra dome built in.
a taller piston never changes stroke length, bv master mechanic
  #30
Old 09-21-2023, 09:22 PM
garygnu's Avatar
garygnu
garygnu is offline
I know this is a very old thread ,but could a stock 534 cam be reground a little bit for more torque/power ?
jbancroft
12-05-2014 11:57 AM
DJdemon6696
09-09-2008 11:41 PM
smooth
07-13-2006 11:21 AM
cbfomoco
10-24-2005 03:44 PM
Rat wagon
15
02-21-2003 01:09 PM
Quick Reply: 534 Rotating assembly
