Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 08-16-2003, 03:37 PM
rhetor rhetor is offline
rhetor is starting off with a positive reputation.
sensor location on block for gauges
i just picked up some guages to replace the 'Normal' idiot guage readings...
I have a temp gauge, and oil pressure gauge, and a ampere gauge.
The ampere gauge is simple, i can do that blind folded...
the temp and oil pressure guage is the problem. Where are plugs in the block where i can put these sensors? hooking them up looks easy enough, but i don't see any holes in the block! (maybe thats a good thing )
__________________
1995 F-150 reg cab long bed DECEASED
I6 300-M5OD-4.10 LS
33x10.5 BFG M/T mild head work, torque cam, 2.5" exhaust, roller rockers, 19lb injectors
New truck- 1971 F-100 2wd 302/AOD
  #2 (permalink)
Old 08-16-2003, 04:42 PM
StrangeRanger StrangeRanger is offline
StrangeRanger is starting off with a positive reputation.
The water temp sender port is on thr passenger side of the block, down low in the water jacket. Do not use the port in the t'stat housing that is for the ECT sensor that feeds the computer. The oil pressure sender is on the driver's side in the oil galley just aft of the filter. Both of them will have senders for the idiot lights screwed into them. In order to keep the idiot lights functional, you need to screw a nipple ant tee into the existing ports anf reinstall the factory sender in one leg and hook your sensor to the other.
__________________
1996 F150 XLT 2WD 4.9 E4OD.
  #3 (permalink)
Old 08-16-2003, 08:21 PM
steve83's Avatar
steve83 steve83 is offline
steve83 is starting off with a positive reputation.
You can change your instrument cluster to the gauge type just by swapping one in. You don't have to do anything at all to your wiring harness, or change the temp sender. The temp gauge will work the way you want.
To get the OE oil gauge to be functional, you have to swap the pressure switch (brass) for a sender (galvanized steel) from the parts store (~$12) for a pre-'86 truck and short across the 20 Ohm resistor on the back of the gauge cluster. Look at this pic:
http://www.superford.org/registry/ve...075&original=1
It's the tiny tan thing in the top R corner of the film circuit with 3 stripes and it says "20 Ohm" above it. That will make the oil gauge real.
__________________
Walk softly & carry a BIG 6!
  #4 (permalink)
Old 08-16-2003, 10:55 PM
thanks guys. Gunna check that out tomorrow after i put a new exhaust on my step dads 2001 F-150 5.4L
it'll sound sweet! hehe
so is the idiot guage just a two position needle?
__________________
I6 300-M5OD-4.10 LS
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
