GlowStep Revolution - scissor step for trailers
The GlowStep Revolution is the first and only scissor step system designed for towables, fifth wheels and side entry campers to be versatile and flexible to adapt to any type of terrain with the All Terrain Landing Gear.
The All Terrain Landing Gear is included with GlowStep Revolution. It connects the step with the ground (Earth to RV) causing the diving board motion experienced with factory steps to be eliminated.
GlowStep Revolution is revolutionary because it is a system. The system works with the GlowGuide Handrail, SafeStep pet barriers and DirtDestroyer shoe cleaning attachment.
The GlowStep Revolution glows in the dark for up to 10 hours and incorporates a step system with accessories. Features a release lever for quick slide out and easily folds into place during transit, significantly improving ground clearance.
Steps are easily added and removed and range from two steps to six steps.
Torklift International uses a hinge design unlike any other in the industry. Bushings are used on each side of every hinge point on the steps. Assembled carefully by hand and adjusted to precise torque maximizes smooth action and ease of use. The bushings act as a bearing surface that can handle significant tension without over-stiffening the step configuration.
The unique bushing design also prevents step hinges from coming loose over time. As the only step on the market with this feature, the GlowStep line of scissor steps guarantee longevity, durability and quality.
It's composed of 100 percent aircraft grade aluminum and stainless steel, has a built-in step tread, no rivets and has a Legendary Lifetime Warranty and is proudly made in the USA.
GlowStep Revolution Features:
Earth to RV: Connects RV to ground level
All Terrain Landing Gear adjusts and levels on uneven terrain (included)
FLEX-ability: Adjusts side-to-side to accommodate terrain
Significantly improves ground clearance when in use as compared to the factory step
Up to 375 lbs weight capacity when used with GlowGuide Handrail
Up to 50% lighter than the factory step
Bushing bearing bolted for maximum stability and longevity
Ability to add and remove steps (2-6 steps)
Works as a system with the Torklift GlowGuide Handrail, Torklift Safestep pet barrier and Torklift Dirt Destroyer shoe cleaner
Proudly made in the USA
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
06-28-2016 10:50 AM
Torklift Sheryl
06-09-2016 12:27 PM
Torklift Sheryl
03-22-2016 09:05 PM
Torklift Sheryl
07-24-2015 11:01 AM
Torklift Sheryl
05-19-2015 01:17 PM
