Cat 3208 Tach Drive - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Cat 3208 Tach Drive
Old 06-07-2016, 11:09 AM
Allisfordih Allisfordih is offline
Allisfordih is starting off with a positive reputation.
Cat 3208 Tach Drive
There is some kind of electric device attached to the front of my Cat 3208 out of my 77' C8000 where the tach cable attaches. What is this electrical thing? What does it hook to? And is it critical for anything? Mine has a split in the case and the wires were cut when I bought the truck. I attached pictures to show what I'm talking about. Thank you in advance for your help.
Old 06-10-2016, 05:48 AM
awhtx awhtx is online now
awhtx is gaining momentum as a positive member of FTE.awhtx is gaining momentum as a positive member of FTE.
Whatever it is it is converting the speed of the rotating tach drive to an electrical signal and sending that signal somewhere.
Did the truck have Cruise Control? Engine Overspeed warning light?
Old 06-10-2016, 08:02 AM
It was originally a pumper truck. No cruise control, and I don't know about an over speed light. The regular tach drive cable hooks up to the end of that device.
Old 06-16-2016, 06:51 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Lower pic: This is the only C series pic there is. 17365 is the tach cable.
Old 07-18-2016, 09:40 AM
Destroked 450's Avatar
Destroked 450 Destroked 450 is offline
Destroked 450 is gaining momentum as a positive member of FTE.Destroked 450 is gaining momentum as a positive member of FTE.
Fire truck have two tachs, one in the cab (factory) and one on the pump panel for the engineer to monitor engine speed while pumping water. The adapter you have most likely sent a signal to a electric tach on the pump panel. This adapter would be an aftermarket add on by the company that built and installed the pumper body.
Fire trucks also had oil pressure and water temp gauges on the pump panel so you should have extra sending units on the engine for those unless someone has removed them.
Cat 3208 thermostat kerrys99f350 General Diesel Discussion 5 07-02-2010 07:16 PM
Badmouthing the Cat 3208 FordMan1981 General Diesel Discussion 9 09-07-2009 12:37 PM
477 vs Cat 3208 TheFirewoodGuy 401, 477, & 534 SD Engines 2 03-06-2007 10:50 PM
3208 CAT in a F-250 PeteyF-250 General Diesel Discussion 50 08-05-2006 10:12 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
