Electical...amps vs volts
Something to think about.
Is 30 amp service 110 volts or 220V?
What about 50 amp service? 110 or 220V?
Was thinking about this as we are going out to Wyo in August and will park the 5th wheel at my Uncles. He has 50 amp 220V beside the house. Got to thinking about it. Each leg of the plug is 110 and then you have the ground. OR it should be wired that way in each 5th wheel.
Am I right?
Am I right?
a friend install an outlet for his New Georgetown ,,, wired it for 220..
you do not want to know the amount of damage that caused.
50 amp "RV" service is 2 branches of 120 volts at 25 amp each. mainly for 2 A/C units or big microwave and toaster oven.
30 amp "RV" service is 1 branch of 120 volts at 30 amps.
A friend of mine learned that last year when we were in Ireland. She thought that plugging her hair dryer into a 220v outlet via a cheap converter would be ok, the sound it made when she turned it on was classic. Needless to say, the 110v hair dryer did not come home.
I actually was working on a 5th wheel with electrical problems and the owner had his buddies who were licensed electricians wire up 240. I came back the next day and rewired from the breaker box in the building out to the camper.
Some times it smokes a lot of stuff. Other times it doesn't do much damage at all.
As I a, sure everyone knows you have two 50-amp 120-volt circuits in the box so you can find 240 volts with your meter at the two 50-amp legs in. 30-amp systems really are on the skimpy side if you want to have everything on electric at the same time and it can be hard to rewire to a 50-amp system as often you have mulitple components on the same circuits so you can not simply split the components at the box without running new wiring.
Steve
Steve
Probably a 50 would be better, but he still has the fifties in the box so all that is not protected at 50 is his shoreline.
Favorite story. I was on a service call as owner complained some of his systems were not working. I found almost nothing through one 50 amp leg. Called campground owner who came over and was shaking the dirt out of the breaker in the pedestal. Asked what he was doing. He told me every year the river at the campground floods and covers over all the pedestals in the lower level of the campground. They just leave em and fix em when someone complains. Long service call for nothing!
Steve
Steve
Received 6,673 Likes
on
