My 55 Ford F100
My 55 Ford F100
here is my baby, a mostly stock 55 Ford F100 conventional with a standard 223 straight 6 and 3 speed on the tree with a cable overdrive, a real barn find that sat for 26 years.
So far all i have done that's not stock is convert it to 12volt and rewire it, though i have done quite a bit of work to it as well, not finished yet its been a 2 and a half year project. feel free to ask any questions and there are more than 100 images in the build log so far.
It is almost driveable too. also it's another one of those mystery Y paint code trucks that's not quite mountain green or sea sprite green, maybe it just faded.
55 ford project truck. - Album on Imgur
current to do list. buy a battery,finish the electrical, hook up the heater hoses, reinstall the seat, replace bulbs, install horn, register, insure etc.
info looked up from vin.
VIN Format: 1953-1960 Ford truck
Decoding: F10D5A24135
Digit Usage VIN Decoded
1-3 Series F10 F100 Conventional
4 Engine D 223 6-cyl
5 Year 5 1955
6 Plant A Atlanta
7-11 Sequential Serial # 24135 24135
Serial numbers are sequential per plant
eventual goals are a/c, power steering, disc brakes, collapsible steering column and maybe a bigger engine.but that will be saved for if I can ever afford to rotisserie it.
5 Year 5 1955
6 Plant A Atlanta
I have the exact truck in red minus the overdrive. Its completely original. Fuel pump finally took a dump and I made too many excuses over the last 15 not to change it and get her up and running again. I have acquired most of the rubber for windows, door kits, IPE wood for bed and plan to use 17" oem aluminum F150 wheels from 2001. Just have to modify the bolt pattern to fit the older bolt pattern.
I also want to swap in a 4wd front axle from donor Jeep Wagoneer back in the early eighties and add a Dana 21 transfer case. The parts are just sitting around with no place to go. The front axle would need hubs and rotors changed over to Ford bolt pattern, but thats straight forward. The axle is only 1/2" off on spring perch centers. Wont take anything to alter and make fit. Leave at stock ride height with axle under front springs and whatever small blocks to level in rear.
I dont care about the paint with surface rust coming thru or seat foam is crumbling to powder. Just want it together and on road running. But this Obama gas doesnt have much of a shelf life on long term projects. Everything I have that is not driven almost daily takes a dump in about six months because fuel goes to crap.
Well thats my story and Im sticking to it.
fking1 theres a good bit of rust underneath it but yes I think its in great condition for its age, most of the body is very solid, especially for a florida farm truck. I eventually want to cut out the floor in the cab and install another one, or reinstall this one since it bobbles up and down due to crappy welds.
das54 I'm not crazy about the color but its got a lot of spirit so I think I'm gonna keep it this way patina and all, but its not quite mountain green or sea sprite green, seems too blue for either, too light for mountain green, and too dark for sea sprite. maybe the sun faded it over the years but all of the paint everywhere is the same color.
5 Year 5 1955
6 Plant A Atlanta
5 Year 5 1955
6 Plant A Atlanta
DevinOwen
02-22-2017 04:27 PM
panzerman200
09-26-2013 08:24 AM
medicpg
05-21-2003 04:41 PM
