Can I change the flex plate without removing the transmission?
Not sure that's the problem but hoping it is. I heard a clunk then no matter what I did the engine just spun.
Well, your starter ring gear is on the flexplate. If you can still start your truck, the issue most likely lies inside the transmission or the torque converter, not the flexplate.
Just took off the inspection / bolt-up cover for the flexplate/torque converter and the flywheel and torque converter are both spinning with the engine.
If I engage the TCC lockup clutch, I get a zinging/whizzing sound that I never got before. Could that mean I have a torque converter or maybe fluid pressure problem?
For anyone wondering about their flexplate... you can check it easily by removing ONLY the cover.
pinkpantherbeekeeper
03-21-2013 04:11 PM
