93 460 vacuum hose question
I have a 93 f350 460 5 speed.
Trying to find out where this vacuum hose goes and what it does.
I also have a spark plug that's really tight and doesn't want to come out. It moves a bit of I use a lot of force but it won't come loose. I just sprayed some wd 40 on it but looking for options on how to get it out. Thanks
No idea on the hose.. But for the plug depending on location. Try getting some heat to it maybe a small butane torch. Obviously clear anything out that's at risk for burning, then take some pliers and an ice cube the the plug. This will cool it and hopefully break free whatever's holding it in, unless it is cross threaded in that case you'll need to drill it out tap it and put a helicoil in, also not a hard task given you have access to the hole.
What does it do if not connected? Vacuum leak?
I have a 94 and 96. One side of the canister has a breather cap, the other has a "F" fitting with a vacuum hose and a larger hose. The larger hose goes under the canister and attaches to a metal line that runs along the frame rail. Crawl underneath and look for a metal line along the top of the frame rail, may be the same for a 93.
RobertELee
02-16-2019 04:53 AM
VinceDee
10-10-2007 01:43 PM
DJdemon6696
08-01-2007 01:40 PM
