5th Wheel Maintenance checklist / schedule
re-torque lug nuts and check air pressure before each trip.
Walk the roof 2-3 times a year checking all vents and seams.
Check tires and level of heat at each hub on fuel stops.
Wheel bearing regrease/repack depending upon the axles you have..
Always check the water level in your battery. At least monthly.
All depends on what brand tires they put on your rig.....or you were just a lucky man. I've seen more 5th wheels and travel trailers on the side of the road here in So. Utah with blown tires and damaged rigs then I care to count. First thing I did was get rid of the GY Marathons and switch to Sailun S637's when we got our 5th wheel home. It's just an FYI to the OP, he's asking so that's my recommendation.
Steve
My rig has been sitting for 18 months & I noticed on this trip the brake shoes are screeching so I know it's time for new ones. I was thinking that since the drums were going to be coming off that it might be a good time to re-pack the hubs. Thoughts?
Also, how often is hub repacking supposed to be done?
Thanks.
When I got my new tires installed last week I had the mechanic squirt some grease into the hubs.
Thanks.
Thanks.
I'm brand new to all this, so "zerk" is a new term for me. He just popped off the cap & squirted grease all around the inside.
People just keep telling me that I need to "repack" them. I guess I don't know what the difference would be, or even if there is any...
thanks.
thanks.
I am sure it was not done correctly. Those that are regreasable need to be off the ground and rotate the tire while adding grease.
You are suppose to put enough in there that the old comes out around the zerk.
I would still recommend a complete cleaning and repack by someone who works on these. At that time I would also replace the inner grease seal as well.
Your RV service dept is probably best to do this.
What happens is the grease as it goes in through the spindle, it hits the end and is forced 180 degrees back through the bearings and comes out the front. The problem is the grease will actually push past the rear seal and go into your brakes. If this happens, you'll be replacing your brakes.
Here's a doc that shows the grease flow. Notice the only thing holding the grease back is the rear seal. Even if you follow their directions to the T, it still can happen.
http://dexteraxle.com/i/u/6149609/f/...s/E-Z-Lube.pdf
Don't ask how I know.. Let's just say I recently replaced 2 out of 4 brakes due to grease contamination.
If your brakes are disc you'll be fine. If drum, chances of pushing the grease past the seal into the drum is pretty high.
If your axles are the Dexter EZ-Lube with the grease zerk behind the rubber plug. You're way better off not using it and repacking by hand.
