Truck is shaking
#33
This may seem unusual but I had a shake that felt like the front end at highway speeds. Thought i tracked it down to front rotors that were original. After replacing the fronts no change. Turned out to be a warped rear rotor causing my steering and what i thought front end vibration. Replaced the rears and shake was gone
I too had this same experience, not on my truck but on one of my cars, kept taking it back to tire shop thinking they had some involvement as it appeared soon after new tires, my steering wheel would shake violently around 70mph. After utter frustration and desperation I took it in and asked to have all four rotors turned, problem solved
#34
#36
I have no idea if this is relevant but here goes. I bought a 2004 Excursion last September. The PO had it to the dealer 5 times for severe vibration above 75. Every time they would re-balance the tires -- a few weeks later back again. They had installed King Ranch 20" wheels. It required a spacer to prevent the tires from hitting the frame. When I pulled them off to find the vibration I realized they had non hub-centric spacers on it -- because of the design of them the spacers could and did move and there was no guarantee that the spacers ever were really centered with the wheels. I replaced them with hub-centric spacers and 7,000 miles later no vibration yet. Just a thought. Do you have spacers or adapters or wheels that are not Ford?
Doug
Doug
#38
#41
036.0stroke,
I do not know about dually wheels but I can give you the info from the site where I got my adapters/spacers -- if anyone would know, it would be them; fred@wheeladapter.com. I know that most Ford wheels (if not all) are "hub-centric" meaning the wheels are a tight fit over the hubs and literally the hubs keep the wheels centered so as they rotate they cannot move. There is another type, "lug centric" -- think about a typical auto wheel -- the lug nuts are kind of "cone shaped" or tapered on the end to literally go into the wheel and the lugs keep the wheels centered. Those are what I had when I bought the Excursion -- they do not work on Fords.
Give wheeladapter.com a look.
Doug
Doug
#44
WheelAdapter.com > Wheel Spacers
This is what I was speaking about -- hub-centric spacers. I am sure there are many others out there -- just make sure they say "hub-centric."
