cylinder head swap
Old 06-05-2016, 12:31 PM
stagecall's Avatar
stagecall
stagecall is offline
cylinder head swap
I have 89 F150 w/300-6 without a head.However I do have a older head that is good.Will this older head fit on the newer motor?
Old 06-05-2016, 04:46 PM
RustFreeBucket's Avatar
RustFreeBucket
RustFreeBucket is offline
I don't see why not, but do you know the condition of the deck and the bottom of the head? They might need be machined, it would be a good thing to check.
Not sure as well but i think I read something about the 240ci head having a smaller combustion chamber and helping make a bit more power, but I would want someone else to verify that.
Old 06-05-2016, 11:52 PM
ID Scrounger's Avatar
ID Scrounger
ID Scrounger is offline
I don't have first hand experience with it but I have read that all of the big block six heads will swap back and forth through all years. However, I do know that the efi head has a smaller combustion chamber about the same size as the 240. Putting a carb 300 head on an efi sorry block will lower the compression. The carb 300 head is 76cc, 240 head is 68cc, efi head is 68cc--all of those are +/- a couple cc because the casting consistency on them wasn't spot on always.
Old 06-06-2016, 01:14 PM
stagecall's Avatar
stagecall
Thanks.I am going to port and polish along with good valve job...
BaronVonAutomatc
04-25-2016 04:22 PM
Hunt89
02-11-2011 07:18 PM
F-250 restorer
10-24-2010 12:23 PM
whipple_ryan
20
07-27-2009 11:46 AM
Bern_F150_4x4
05-01-2003 01:30 AM
Quick Reply: cylinder head swap
