Leveling kit questions, advice needed
Old 06-05-2016, 09:23 AM
DeathValley1981's Avatar
DeathValley1981
DeathValley1981 is offline
I have finally gotten back into an F150, a '12 XLT with the 3.7L.
I want to level it and have read pretty much everything I can find online about it. I think that I want a 2" and not 2.5". I have read that autospring is popular and have heard good things about hell bent steel. I won't be doing the install myself and have read that 2012 models have EPAS and that needs to be addressed during install.
I would like some recommendations on brand, height and install instructions that my mechanic may not know about that some of you may have learned the hard way (sorry).
Right now I'm thinking the 2" billet hell bent steel kit and making sure my mechanic disconnects the battery during install. Is that about all I need to know?
Be kind, first post!
Old 06-05-2016, 09:42 AM
MCDavis's Avatar
MCDavis
MCDavis is offline
Measure your truck. That's the only way to determine what will get your specific to I I leveled. Also, not everyone looks at "level" the same way. Some guys like a bit of rake. Some guys like nose high. Measure measure measure.
HBS and AS are both fine options.
Old 06-05-2016, 11:49 AM
CuNmUdF250's Avatar
CuNmUdF250
CuNmUdF250 is offline
It's a spacer any brand is fine.....I can't recall ever hearing or reading of a single spacer failure. So as mentioned you just need to figure out what size you want/need.
Old 06-05-2016, 11:57 AM
DeathValley1981
Thanks for the replies, I think I'm going to go with the 2" Hell bent steel billet kit.
Any advice on install other than aligning afterwards? As I said I'm not doing it myself, trust my mechanic but since this isn't something he does everyday and lots on here have done it, wanted to get an idea of pitfalls to avoid before installing on my '12.
Old 06-05-2016, 12:05 PM
CuNmUdF250's Avatar
CuNmUdF250
I'm no mechanic either, had a shop install all my stuff. I think I've read where some guy installed his backwards....I'm not even sure how that'd happen but other than that they are pretty straight forward.
Old 06-05-2016, 12:38 PM
NASSTY's Avatar
NASSTY
NASSTY is offline
The 2" and 2.5" Autospring spacers are offset and the driver side spacer has "D" stamped on it. If they are not offset like the Autosprings they aren't side specific and can't be installed backwards.
Old 06-06-2016, 08:54 PM
King-bRanch's Avatar
King-bRanch
King-bRanch is offline
Leveling Kits are very easy to install fella's, think it would surprise u
Seems like u are leveling yours, by raising your front end (perfect if u have a 4x4).
Since I have a 2WD (first one in over 10 years probably, lol) I am leveling mine by lowering the rear end.
Spent some time looking & ordered this Shackle Kit by Ford Racing today....
https://performanceparts.ford.com/part/M-3000-G
Can't wait for it to arrive
Old 06-07-2016, 03:32 AM
karlduke's Avatar
karlduke
karlduke is offline
Spend a little more and consider Bilstein 1500's to level your truck. These adjustable shocks can improve ride quality also.
Old 06-07-2016, 06:57 AM
King-bRanch
Note on those.... "Designed specifically for LIFTED pickups, SUVs and Jeeps"
Old 06-07-2016, 09:26 AM
ubereal2's Avatar
ubereal2
ubereal2 is offline
King-bRanch, it's good to see another NC person here on the forums. Ever get on the North Carolina Forums? I'm in there, here, and in the 73-79 forums.
Unk Bob
Old 06-07-2016, 03:38 PM
NASSTY's Avatar
NASSTY
NASSTY is offline
5100's are height adjustable 0", .75", 1.5", 2.25". You can run them at stock height as well.
Old 06-07-2016, 04:48 PM
Larietpsd's Avatar
Larietpsd
Larietpsd is offline
So what's a good kit
Old 06-07-2016, 08:41 PM
MCDavis's Avatar
MCDavis
MCDavis is offline
Well, there's a "good kit" for every budget, from the $100 AutoSpring spacers to the $250 Bilstein 5100s, to the $800 Fox or F150lifts.com coilovers, to the $1200 Icons, and I can keep going.
Old 06-09-2016, 12:35 PM
Buck268's Avatar
Buck268
Buck268 is offline
Uhg, had a nice long post about my 5100's but it got 75% deleted. Suffice it to say I like them a lot, even comparing to a new 2016 with
Old 06-10-2016, 08:25 AM
King-bRanch
Unk Bob
Yes sir, been on the SuperDuty side almost 5 years now. Haven't really played on the NC Forum that I can recall, I'll check it out when I can though.
Quick Reply: Leveling kit questions, advice needed
