1988 Ford F250 460 problems??
Hey guys wandering if you could help me out. I have a 1988 F250 with the 460 engine. It will run fine when I crank it up cold, but after it warms up it will cut off. It starts to hesitate then cuts off even when i am pressing the gas pedal.
We put on a new fuel tank, fuel pump, fuel filter, and distributor with ignition module, no change.
If any one has run into this problem LMK, need help.
The following users liked this post:
Those look like Key On Engine Running codes. It's highly advised to run the Key On Engine Off (KOEO) tests and Stored Code (Continuous Memory) display. Fix any issues flagged there first, then go on to the KOER.
In either case you can trigger a false Code 21 if you do not warm up the engine first.
r9wolves
12-02-2014 10:04 AM
mpmccarthy
07-05-2004 07:13 AM
