Newbie w/ 429 question
'74 Highboy, original engine was a 390 if I'm decoding the VIN correctly. But a PO dropped in a 429 (allegedly, b/c haven't got the oil pan off to check the numbers to be sure). If so, God knows when.
I'm getting smoke out of the right side of the motor. Also, bought it from out of state and trailored it home, and thank God I did because when I drained the oil pan I got a whole 1/2 quart out if it! So, for me right now the motor is sketchy.
If it comes to a rebuild, must I do anything exotic as to parts to get 350-400 hp out of the motor while maintaining a reliable motor? I'll confess I haven't searched this forum but I'd appreciate your opinion and any suggestions to get to where I'd like to be hp-wise. And I thank you for your time.
Vic
Vic
Most people will convert their 429 to a 460 if it needs a rebuild. With that said here's some info to check out. Good luck with it and let us know how it plays out.
460 Horsepower Chart (revised 1/24/09) - 460 Ford Forum
johnnys69highboy
01-31-2012 07:31 PM
SL1CKR1CK
38
08-03-2008 01:54 PM
Green Streak
11-18-2005 01:59 PM
