C6 Transmission Filter change? - Ford Truck Enthusiasts Forums
Old 08-16-2003, 10:27 AM
390man 390man is offline
390man is starting off with a positive reputation.
Question C6 Transmission Filter change?
I pull a 25ft Gooseneck trailer with my 1975 F-250 4X4 with my antique tractors. I want to change my tranny filter, How many quarts to refill, and what do you think about replacing the old fluid with synthetic tranny fluid?? Can a person tighten the bands in these C6's.. Thanks for your time and help..........390man
Old 08-17-2003, 08:11 AM
cartwright cartwright is offline
cartwright is starting off with a positive reputation.
I dont remember the fluid capacity. You can adjust the intermediate band. The screw is on the left side of the case. Put a new lock nut on the screw. Tighten the screw to10 ftlb's, then back it out exactly 1.5 turns. Tighten the new lock nut to 40 ft lbs.
Old 08-17-2003, 06:39 PM
rclarke rclarke is offline
rclarke is gaining momentum as a positive member of FTE.
The filter in a C6 is a simple screen. If it appears clean and the fluid is clear it really doesn't need to be changed. The C6 holds 11 -13 qts of fluid. Drain the torque converter and clean out the pan. Pour in 6 qts then start the engine (trans in Park) add 4 -5 more qts then check with the dipstick. Most 4x4's hold about 12qts when serviced and as much as 13qts on OH. While the band is certainly adjustable the friction material is so thin that if it needs to be adjusted it likely is worn out. Check the dipstick for the right fluid, in 1975 C6 used type F fluid. The first use of Dexron was in May of 76.
Old 08-18-2003, 05:28 PM
Thumbs up C6 Transmission Filter change?
Thanks guys for the info on the C6, it is really nice to have a forum like this and people willing to help!! Thanks Again...
390man
overheated c6 tranny 87classic460 1967 - 1972 F-100 & Larger F-Series Trucks 15 04-16-2015 04:01 PM
Converting to Automatic Trans - cooler question Vin Man 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 12-25-2012 10:16 AM
Auto Tranny Fluid Blue and White 1973 - 1979 F-100 & Larger F-Series Trucks 9 01-01-2012 12:15 PM
Tranny Fluid Change nflfreak43 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 38 07-09-2009 06:56 AM
C6 capacity dkchristensen Clutch, Transmission, Differential, Axle & Transfer Case 2 01-04-2003 10:27 PM
Tags
150, 4x4, 77, c6, capacities, change, filter, fluid, goosenecks, replacement, specs, torque, tranny, transmission, transmissions
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
