2.5 inch leveling kit install
Hey guys, I figured now is a good time to get my leveling kit installed with the 100 degree plus weather so I packed up my kid and we drove out to my dads shop. Thankfully He has plenty of tools, AC and a fridge full of ice cold beer.
I went with Supreme Suspensions 2.5 inch billet spacers and i replaced my stock shocks with daystar 2.5inch front shock absorber. Total cost was just over 100 bucks. I shopped around and found a few deals on the shocks and got free shipping. Heres some pictures of before an after. It totally changed the look of the truck. As far as the ride, it didn't seem to change it much at all. I has my truck realigned, the guy who did it said it was off a little but not by much.
before
during
almost done
done
highly recommend getting a spring compressor. You'll have a hard time getting the spring back in with the spacer...
before
during
almost done
done
Nice job looks good done the same thing, you might want to also get a adjustable track bar so you could put the axle back in the right location. My truck is only 2 inches lifted move the axle a half an inch toward the driver side sort of shocking trying to decide which relocation bar to buy or possibly a drop down bracket and use the factory bar. ReadyLift make a nice system but I wasn't going to keep the truck this long so I use the cheap 2-inch blocks underneath the springs truck seems to be riding fine just don't like the bump steer characteristics of the axle being off center the cheapest one I found so far is about $400 kind of ridiculous a piece of steel with nuts on it that lock to the right length lol take care
Don't need a adj track bar for 2", especially if your goal is low cost.
Horizontal axle offset has nothing to do with bumpsteer. An adjustable bar will not change handling. Installing a drop bracket on only the tack bar can actually create a bumpsteer and make things worse (w/o drop pitman arm).
Here is the math. Note the angle are not equal stock as the bars are different lengths.
Track bar:
Stock - length = 37”, angle = 8.5 degrees
2” lift - angle = 11.7 degrees, change in horizontal distance = 0.4” to the left, change in angle = +3.2 degrees.
Drag link:
Stock – length = 43” angle =3.3 degrees.
2 lift – angle =5.7 degrees, change in angle = +2.4 degrees
Radius arm:
Stock- length 38”, angle 0.5 degrees down
2” lift – angle = 3.5 degrees down, change in caster = -3 degrees
Hmm... What were the numbers? 'Off' here means you have little caster and it will drive as such.
You should be able to easily install the spring. Something limiting axle droop was causing you an issue. Did you flip brake line brackets? Other items are sway bar links, and ABS/vacuum lines.
Track bar:
Drag link:
Radius arm:
Track bar:
Drag link:
Radius arm:
Great info. What would the numbers be for a 1.5" lift in front?
Thanks
Stock - length = 37", angle = 8.5 degrees
1.5" lift - angle = 10.9 degrees, change in horizontal distance = 0.3” to the left, change in angle = +2.4 degrees.
Drag link:
1.5" lift– angle =5.3 degrees, change in angle = +2 degrees
Radius arm:
1.5” lift – angle = 2.7 degrees down, change in caster = -2.2 degrees
Track bar:
Drag link:
Radius arm:
Drag link:
Radius arm:
Would the numbers change with an adjustable track bar other than the track bar length and left offset .3 inches ?
Thanks
I am so glad to see someone putting the numbers to work. I end up doing this exact thing for everyone i know. A tape measure and some highschool geometry works wonders. I just leveled my 16 lasts week. My digital angle finger confirmed my calculations to within a tenth of a degree. I use an engineering degree for more trivial things than engineering anymore.
No, all the other values would remain constant regardless of trac bar length. IMO a $500 trac bar isn't justified for <2" lift. You will need a serious ball joint tool to remove it.
Thanks, yes they do. No guessing, planned results. Here's where the math came from if your interested...
https://www.ford-trucks.com/forums/1...nd-theory.html
Tedorama
2017+ Super Duty
29
01-14-2019 06:18 PM
