ordering supplies
Not knowing the sizes wont help me when i chase the threads with a tap to clean the 60 year old threads up from the east coast rust. Most of my trucks were in pieces when i bought them so many of the bolts were out already leaving the holes open to the elements. I know most are just 1/4-20 and door stuff is 12-24. I thought someone would of had a list by now.
You asked the most used those are the ones I use the most. You need carriage bolts, special bolts for cab mounts, fenders ect
There is a fastener supplier here in town named Ababa Bolt, they have virtually anything that I have ever needed in the way of hardware. I have been told that these shops are commonly found near airports...which is the case here. I buy most items in bulk there, usually in boxes of 25 - 100 pieces. Storing these boxes got to be a hassle until I found these cabinets, they are a great investment and make getting to the piece you need very simple.
Just a head's-up on stainless fasteners: in case you aren't aware you need to use either anti-seize or Maalox on the threads before assembling or you'll end up worse off than you would have using un-coated hardware. Stainless fasteners will gall when assembled without a coating. Maalox is the preferred coating (cheaper and won't make you look like the tin man.) And never, ever use stainless bolts and stainless nyloc nuts without coating, especially in areas exposed to the elements otherwise you might as well just go ahead and weld the pieces together.
Funny thing, my '53 is pretty much original and I have yet to break a single bolt. They all come apart as if they were assembled yesterday.
I see what's in it here, but what makes it good as an anti-seize?
"Maalox Advanced liquid products contain the antacid ingredients aluminum hydroxide and magnesium hydroxide for the relief of acid indigestion, sour stomach, heartburn and upset stomach due to these symptoms, and the anti-gas ingredient simethicone for pressure, bloating and fullness commonly referred to as gas."
Sorry about the hijack...
