96 Axle replacement
96 Axle replacement
Okay, so after many years of a rear end noise that is getting worse, (God bless my Areo), I need to replace my rear axle. It's a B4 and I was wondering if there would be any advantage of going to an 8.8" vs the 7.5" that's in it. Would it be a direct bolt up? I don't tow like I used to,(#6500 travel trailer),....obviously what lead to the failure, but this van just works for me and I still will occasionally need to tow a few tractors around. Thank you!
I was thinking of this also I contacted some members on the other fourm and it appears the awd had the 7" rear. The rwd had the 8. This is a common swap my awd has a mustang aluminum drive shaft. I don't know why some have aluminum and some steel. I would look for a possi rear if your rwd.
I think all (or most) of the AWD Aerostars originally had steel driveshafts but they where recalled and replaced with aluminum ones https://www.automd.com/recall/campaign_c16277/
Mannikko94
07-21-2016 12:38 PM
Franken-Truck
10-04-2003 11:10 AM
