Adding Emissions Equipment Back - 1986 302
Picked up a 'new to me' 1986 Bronco this passed weekend. When I picked it up I noticed the smog pump missing. PO said it had seezed on him and he took it out. From what I have seen under the hood, there is a blocked tub that goes to the back of the engine (3/4" ID). Reading the emissions label on the truck I see the vacuum line that goes to the diverter valve is pinched close. I'm assuming PO did this to fix the obvious vacuum leak.
Looking online at new smog pumps I don't see where the diverter valve will go. When I had my 1985 F-150 EEC-IV Carb, the diverter valve was mounted on the smog pump. The pics for the 1986 smog pump just has a tube coming out the back.
What I need, and I've been unable to locate, is a diagram or picture of what a proper 1986 302 EFI CA emissions system is supposed to look like. Can anyone snap a pic of theirs for me?
The Bronco was originally labeled for California sale and so I need to bring it back up to California 1986 specs. I'm in Cali and unfortunately this is a must. Besides EEC-IV thinks that stuff is still there and need to put it back.
So I've learned that it goes from:
AIR (Smog) Pump, to (I think)
AIR Bypass Valve (the left one in the image below I believe), THEN
AIR Control Valve, THEN TO 1 OF THE FOLLOWING
- AIR Check Valve them to Catalytic Converter, OR
- AIR Tube to Intake Manifolds
Another diagram showing EGR related components but not showing AIR Pump connections.
Still can't find how all this looks put together. I will verify AIR Tube is still installed (assuming so) as well as other components.
Unless someone is wanting to get rid of their smog pump and related equipment, I'm willing to buy it off of you.
Info in this thread may be relevant: https://www.ford-trucks.com/forums/1...of-engine.html
Some photos and diagrams in Post# 9. Not sure if your 1986 has the same plumbing as the 1994 in thread. F150/Bronco share the same secondary air injection components that inject air into the back of the heads. The F250/350 inject air into the exhaust manifolds.
That truly helps out a lot!! I know my year didn't use the combined bypass/diverter valve. They are separate components. Though this diagram and engine picture helps.
I think I have a better understanding.
Pump then Bypass Valve then to Diverter
Diverter then Check Valve (screw type) then AIR Tube, or
Diverter then Check Valve (slip on) then Cat
I'll take pictures of what I have currently today after work.
EDIT: So you can see the plumbing for the thermactor system on the back of the pulled engine in this photo. This gave me a good reference for how it's supposed to look.
So this helped me out too. It turns out the PO only removed the pump and bypass valve. I have the diverter valve and both check valves, 1 on the AIR pipe and 1 on the manifold.
Ordered a used pump/pulley and bypass off of ebay and will hope it works. If at least, I have the pulley now which seems to be hard to find for '86. '87 are all over the place. Don't know if they are interchangeable.
The following users liked this post:
marine1200
17
09-30-2015 02:34 PM
peter_x
07-14-2011 09:30 AM
dcassidy
09-30-2009 12:09 AM
