Transmission Problems HELP! HELP! HELP!
2006 F250 5.4l 4x4, long box, quad cab
Current issue: No overdrive / slipping into neutral / rough going into reverse
Codes: sorry i don't have exact code but will get (p0755)... but shows shifting solenoid B malfunction ( this is the OD/Reverse one) check engine light on and tow light blinking
So whats been done: shifting solenoid B (OD/Reverse) was replaced (used part) inspected valve body and o rings... all good... worked for a week... then exact same issue. Transmission showed no signs of gear damage, oil looks good
Next: Replaced shifting solenoid B again (new one) and transmission wiring harness. Still no change, same codes. Seems to be having a communication issue between transmission and PCM? However continuity of wires and connectors seems ok. Thoughts? help
One more piece of interesting info. Every-time before the truck slips I hear clicking coming from the fuse/relay panel under dash drivers side. No clicking no slipping... however never goes into OD at any time.
Any thoughts is greatly appreciated... I am stuck
Cool
G
Cool
G
My thoughts are that I don't know if this is or is not the code that is shown. I don't know if there are more codes. I do know that just replacing parts never works, as you're proving.
Find out what codes are really there and maybe I can help. Right now all I can tell you is that it doesn't look like it's working right.
And there is no OD/Reverse solenoid. The story on this is all mixed up. Get the real codes.
Thank you ....and
Sorry for the confusion. I don't have the truck with me.... its with a mechanic. I will get specific codes ... however I am confident they identified shifting solenoid B as the problem. It always the same two codes. There is also P0174 code.. swapped out o2 sensor...no change... haven't investigated further as transmission issue seems to take precedent.... I will get codes first thing in the am.
G
G
DWStarrider
06-28-2017 12:10 PM
UGA33
02-17-2017 10:09 PM
