Help with egr codes
#31
I know you have Speed Density...MAP = Manifold Absolute Pressure sensor. It's located on the passenger side of the engine bay on the upper firewall.
For reference:
No, I do not believe the vacuum lines are in very good condition. 20+ years of heat take their toll.
That's one way to do, although not my preferred method.
Here is another:
I went real cheap a few months ago and used my shop vac setup in "blow mode". I placed a smoldering cigar inside...it works like a charm.
For reference:
Here is another:
#32
For reference:
Here is another:
AUTOMOTIVE HOMEMADE SMOKE MACHINE 10 BUCKS - YouTube
For reference:
Here is another:
#33
#35
#39
#40
I did a couple days ago the only thing i noticed was the ac compressor making that horrible grinding sound.. I put a metal rod against everything that could be making that sound but cant find anything yet. Ill try again tomorrow. Still trying to find time to do the smoke test.
#41
#43
Rough idle has everything to do with ignition and fuel as well as accurately metered air (vacuum leaks). Add in equal compression in each cylinder. It's a big recipe to decipher.
#44
#45
But u said its common for the intake manifold gasket to go bad right?
