93 aerostar 3.0 bogs under acellaration no power.
Hello, i am new here as well as new to fixing my own car. My 1993 ford aerostar 3.0 is a great vehicle but recently its been killing me trying to figure out what the cause is. I'll start at the begining. I had a job over the hill in Westwood Ca. Ran low on gas on the way home. To low apearently. Since i refuled it has a really rough idle and no power under accellaration. After it gets warmed up i get a bad smell of gas and exhaust in the cab. Now if i turn it off wait 15 min or 12 hours it will run ok for 2 min then back to hell. I has not stalled and i have replaced the fuel filter and a few months back i cleaned the Mass air flow sensor and replaced the TPS. I would love to take it to a mechanic but as i have been living in this old girl for the passed 6 months money is non-existent.
Just hoping that i can get a lead as to what to do.i have even tried diconecting 1 at a time... the TPS, MAF, and the 02 senser. No differance. Opions? Advise? Anything will be appreciated. Thanks. Oh by the way did i mention that there has been no check engine light untill i tested by didconnecting TPS etc.
How low did you run the gas? Did you actually run out?
The worst thing that can happen with running out of gas is the fuel pump will overheat, and possibly burn out. It uses the fuel itself to keep cool. A quick test would be to listen to its operation; it should be a smooth hum. You can also check the pressure at the fuel rail with a gauge that has a Schrader valve adapter. It should have about 40 psi with the vacuum line removed from the regulator.
Update:
The leak could be caused by a plugged up cat or other exhaust restriction - I had this same exact thing in my wife's 3.1 chevy - smoke will find it;'s way somewhere…. so under the hood, you might see it coming out somewhere pre-cat…. hit the gas, and it would just bog down….
I could be wrong here, but I bet a lot of cats are getting older in these, and robbing us of good power…
BrownBronco54
1978 - 1996 Big Bronco
03-20-2004 09:04 PM
