front caliper bolts
Old 06-02-2016, 01:57 PM
Hank85713's Avatar
Hank85713
Hank85713 is offline
Question front caliper bolts
What is the trick to getting these retainer bolts loose? Have tried impact gun, tried long breaker bar hitting their mount with hammer nothing seems to work! trying to install new rotors and pads. On 04 FX4.
Old 06-02-2016, 02:16 PM
mtfuji's Avatar
mtfuji
mtfuji is offline
No trick, try PB blaster and let then soak, then lots of huff and puffing
Old 06-02-2016, 02:17 PM
Jmoen7's Avatar
Jmoen7
Jmoen7 is offline
Penetrating fluid, and then heat if that doesn't work. A few days before brake or suspension work i would also hit the fasteners i'm removing with PB Blaster a few times a day to give the best chance. Everything rusts up pretty easy down there
Old 06-02-2016, 02:19 PM
pass1over's Avatar
pass1over
pass1over is offline
I Just had to remove front caliper bolts on my 550 for a 4wd front end swap. I put an 18" long 1/2" breaker bar on there with the appropriate socket and used a cheater bar. Think it was my jack handle. It worked but was still a bit tough to get off. PB Blaster for sure.
Old 06-02-2016, 03:15 PM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
That lock tight they use from the factory is stout on the retaining bracket. I use a 5ft pipe to get it loose then the impact.
Old 06-02-2016, 06:04 PM
TooManyToys.'s Avatar
TooManyToys.
TooManyToys. is online now
Received 2,068 Likes on 1,400 Posts
I've told this before. One of my guys, stoutly built, with a Superduty on a lift at the proper height, following our company EHS safety rule and methods, tore through a biceps tendon removing one of those bolts. EHS working procedure was rewritten so we could only remove those bolts with an impact, usually a really good 1/2" or a 3/4" air impact at 100psi. It was us in the facility that all agreed to that change.
Old 06-02-2016, 06:24 PM
gwh1bass's Avatar
gwh1bass
gwh1bass is offline
I had to use a hydraulic jack under the end of a long breaker bar to get it loose.
Old 06-02-2016, 07:01 PM
Hank85713's Avatar
Hank85713
Ok guys thanks, finally got them loose and now have been waiting on tech support from the place I ordered everything (3hrs so far). The new pads were not drilled for the separator springs and they have not gotten back as to whether they sent wrong pads or the springs are not required! They indicated I orered wrong stuff but it was their recommendation of what I ordered!
Again thanks, have 1 side apart waiting on their reply.
Old 06-02-2016, 07:23 PM
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
Ouch!!!!!!!!!!
Old 06-02-2016, 07:26 PM
TooManyToys.
I just posted this on the org.
The springs were part of ~2001 maturing of the product line to try to keep the pads off the rotors and prevent rotor pulsation from developing.
Old 06-03-2016, 01:11 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
We are talking the anchor bolts?
Heat on the threaded end to help break down the locking compound
and a 1/2" impact wrench works wonders. Most of the penetrating oils
won't do you any good when thread locking compound is used.
But if I am using penetrating oil (Kroil my favorite) I like to do the heating
first then spray the oil on the bolt to cool and draw the oil in any openings.
Then take the impact and whack the snot out of it.
Sean <BR>
6.0L Tech Folder
widebody95
1997-2006 Expedition & Navigator
13
06-24-2012 12:05 PM
gregrw
18
05-25-2011 11:01 PM
riggz
1999 to 2016 Super Duty
05-23-2009 12:38 AM
brandstruck
11-18-2008 11:13 AM
Alan'sExpy
07-29-2007 09:21 AM
Quick Reply: front caliper bolts
