prothane bushings on core support
I found a video on the core support kid. the small one goes on the bottom then the frame then the large bushing but then there was other parts I don't have. Some due to rust out and there was another rubber pad. I don't know if I need it or not. I did the rest and it was a Pain in the ***. I took the bed off to make it easier. while it was off added larger fuel tanks. You have to remove the front tank to get at the rear cab support. I cut mine in half due to total rust fusing them together. It was still a pain as that old rubber does not like to cut and causes lots of heat. There isn't any room for a cut off wheel. there is a video showing how too remove them fairly easy if you can unbolt them.
JB78f150
03-20-2012 12:50 PM
stangtruck87
04-16-2011 10:13 PM
