'94 F250 Speedometer/odometer not working, truck isn't shifting
Hello. My truck is a 94 F250 4x4 with a 460 and E4OD. I have come across an issue with my truck's speedometer and odometer intermittently not working, and when the speedo/odo aren't working the truck will not shift. The first time, they only quit working for about 10 seconds and it fixed itself while driving. The second time it happened, I had to park the truck and I tapped on the gauge cluster a few times with my hand and the odo came back and and the speedo worked and the truck shifted. Not sure if that was just a coincidence, but it seemed to start working again as soon I I tapped the cluster.
I understand it could be a few different things such as the VSS, VSS wiring, or something behind the dash such as the PSOM. Since the speedo and odo stop working at the exact same time, and the truck won't shift, does this point to the PSOM more rather than the VSS? So far I've pulled the interior fuses and checked them, and looked at the wiring under the dash and some of the VSS wiring. I pulled the codes and the only codes I got are 553, 212 and 332.
Any inputs/suggestions are much appreciated, thanks.
on
ScorpionKing
54
01-12-2021 11:37 PM
arkredneck
08-31-2007 10:13 PM
79f-250custom
08-14-2006 01:46 AM
harryjdukeal1
12-07-2005 03:24 PM
