Massive Coolant Leak Into Oil - Ford Truck Enthusiasts Forums
Old 05-30-2016, 07:27 PM
aeffertz aeffertz is offline
aeffertz is starting off with a positive reputation.
Hey everyone,
I hope I can pick your brains here. My parents have an '07 F150 with the 5.4L. Apparently they were driving it one day and the temp garage rose drastically and was maxed out by the time they got home. Very Short trip and limped it home when the temps were getting high.
When they got home they let it cool down and checked the coolant levels. Empty. No white smoke from exhaust or loud bangs when they were driving it last. Still fires up and runs fine for the very short period of time I tried it. Here's the thing, when we attempt to add coolant to the system, it drains straight into the oil pan quickly. Not over night, but within a minute.
Once it was cooled off, we drained the oil and it wasn't cloudy/milky. But rather antifreeze and oil separated. The dipstick oil had antifreeze and oil on it but was way over the full mark.
With it getting hot I hope it didn't warp the head, but I don't think they drove it long enough for that to happen. Naturally when there's coolant in the oil you think a head gasket or intake gasket but like I said earlier, there was no white smoke coming from the exhaust when the problem originally occurred and the coolant drains so quickly I want to think it's something else. I don't think it's a hole in the block or anything as it runs fine still and they did t hear anything loud pops or bangs when the temps started rising.
Any ideas? Front engine cover?
Old 05-31-2016, 07:14 PM
flyguy108 flyguy108 is offline
flyguy108 is starting off with a positive reputation.
Try an engine stethoscope. Drain the oil and put a large pan underneath the truck at the oil drain. Pour water (it's cheaper than antifreeze) into the radiator and start listening to different parts of the engine and see if you can hear where it is leaking into the oil. If you can pinpoint a spot then that's at least a starting point to figure out if it's a head or a cracked water jacket ect... Hope this helps because I would really like to know what it is.
Old 05-31-2016, 10:27 PM
tbear853's Avatar
tbear853 tbear853 is offline
tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.
Sounds like what happened to my '65 GTO when the timing chain cover which also served as the rear wall of the water pump developed a hole from erosion or something. This was back in the '70s, I wanted to cruise ..... three times one night I had it on a lift, let set a little bit, opened oil drain and drain coolant out, put plug back in, top off coolant, cruise more.
I replaced the timing chain cover (a cast aluminum piece) and a few weeks later .... had to do it to my GF's GTO.
Intake Leak or Head Gasket Leak? 73FOMO 1987 - 1996 F150 & Larger F-Series Trucks 3 08-23-2016 03:14 PM
Getting Concerned 2007 F-250 mwoolard1912 6.0L Power Stroke Diesel 6 11-30-2015 07:32 PM
95 5.8l white smoke 75_92_95 1978 - 1996 Big Bronco 6 05-13-2014 11:23 AM
anti-freeze in oil 2000 Mountaineer??? pilot4x41 Explorer, Sport Trac, Mountaineer & Aviator 9 02-16-2012 09:16 AM
Blown Head Gasket? donjuanit0 Modular V8 (4.6L, 5.4L) 1 03-09-2011 05:10 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
