1994 7.3idi flatbed Fsuperduty tail, turn, running and brake lights out!!!!!
First off my driver side brake light with stop working. I took it apart to try and find the short. In the process I shorted out all my running lights tail lights and brake lights and turn signals I think also. While I was looking for the short, turn signal wire from my tail light touched the frame and grounded out and that's when all the lights died . My tail lights are some cheap trailer lights without reverse lights. I pulled headlight switch from another Ford truck I have. On the harness connector that connects to the switch which wires should read what when I test with a voltmeter?I checked the fuses in the power distribution box under the hood and they were good. Truck has a flat bed so I don't know if that matters with the wiring, I suspect it's different then a normal bed truck. Wiring on the bed is old, maybe from 94. I am unexperienced with electrical, so if anyone knows an easy way to find a short please let me know.
On the headlight switch connector, the power for the running lights comes in on the tan/white, and leaves on the brown wire. There should be a fuse in the underdash fuse box for the tan/white wire.
There will also be fuses for the turnsignal lights and the brake light circuit. Check in the underdash fuse box.
Received 3,101 Likes
on
gfburke
08-18-2018 07:15 PM
digitalrancher
03-07-2007 07:26 AM
jdominicg
09-26-2003 04:25 PM
truck35
12-02-2002 03:14 PM
