Let's talk ebp feedback sensor.
There have been some weird results of a defective ebp.
The compression numbers on this truck are so much better than green...y...?!?!?!
I was windering the same. You wouldn't have compression numbers like that if your pistons looked like Adam's did.
I really think if he can cure the plume of startup smoke that that will be the cure for all issues. Is it base engine or otherwise I do not know. I would be turning more stones as there are parts to be borrowed to test with.
You hear that Thomas? Quit hem-hawing around and do something! That's the only way stuff gets done. No more thinking about it. Just do it. Hmmmm, seems like someone else has said that here before.
Have you gutted the EBPV? Even if its only slighly closed more than it should be you would have low power and high egts. I drop EBPVs like hot potatoes!
You hear that Thomas? Quit hem-hawing around and do something! That's the only at stuff gets done. No more thinking about it. Just do it. Hmmmm, seems like someone else has said that here before.
I say no more.
I believe it's a matter of money and not a matter of ambition. Even with free parts you have to get them to yourself somehow... And most Options at this point are shooting in the dark anyhow
