1948 Ford F-4 rear end grind - Ford Truck Enthusiasts Forums
Old 05-29-2016, 02:36 PM
F4Bob F4Bob is offline
F4Bob is starting off with a positive reputation.
My 1948 F4 (flathead V8, 4sp synchro, 5.83 rear) is having some major grinding issues in the back right hub.
Sounds like the bearings.
My questions is how do I remove the axel. My manual isn't too clear on the subject.
Also- any recommendations on other service I should do since I'm about to go deep in the back end?
I have the brake drum off and all the nuts removed from the axel.
Any help would be appreciated!
Old 05-29-2016, 02:52 PM
oldmerc's Avatar
oldmerc oldmerc is offline
oldmerc
oldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to all
Youtube full floating axle removal
Old 05-29-2016, 03:07 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Remove the axle and you'll see the large nuts that secure the hub to the housing. FWIW, there are some UTube procedures that are obviously done by "hacks". Get a wrench to remove and replace the large nuts. Have fun.
Old 05-29-2016, 03:20 PM
49fordv8f4's Avatar
49fordv8f4 49fordv8f4 is online now
49fordv8f4 has a very good reputation on FTE.49fordv8f4 has a very good reputation on FTE.49fordv8f4 has a very good reputation on FTE.49fordv8f4 has a very good reputation on FTE.
You will need to remove the nuts and tapered lock washers from the studs holding the axle in the hub. There are two jack screw holes in between two of the studs on the axle head, sometimes they work sometimes they don't. I have seen quite a number of axles with jack bolts twisted off in them. If the jack bolts don't pull the axle loose, you have two options, double nut the studs and remove all the studs or use a hammer about 3lbs and pound on the center of the axle head. Pounding on the head will cause the tapered lock washers to back out where you can remove them with pliers. Once the axle is loose, just pull it out. There is a pair of 8 sided nuts about 3 1/4" across the flats to adjust the wheel bearings. You will probably notice that a PO has removed the outside one with a cold chisel, very common, as most don't have the proper socket. There is a keyed washer between the nuts. When you get the hub off please notice that there is a snap ring behind the grease seal that must be removed before you can drive out the seal. I can give you the National and C/R numbers for the grease seals when you are ready to reassemble.
Mark
Old 05-29-2016, 06:35 PM
Flat48's Avatar
Flat48 Flat48 is offline
Flat48 is starting off with a positive reputation.
Thanks. Got it off.
Lots of metal glitter inside. Bearings done it seams...taking the nut off once o get the socket.
Quote:
Mark
Old 05-29-2016, 06:36 PM
Flat48's Avatar
Pics
Quote:
Originally Posted by Flat48 View Post
Thanks. Got it off.
Old 05-29-2016, 07:36 PM
raytasch's Avatar
I would suggest the next step be to drain the differential to see how much water comes out. I see some in the axle housing. If the differential is full of water and the bearings are dry, the rear end may be history.
Old 05-29-2016, 08:56 PM
CaptPayne's Avatar
CaptPayne CaptPayne is offline
CaptPayne is starting off with a positive reputation.
And if you are doing one side... do the other. Especially if the diff oil doesn't look great. The drivers side could be close behind, might as well do some preventative maintenance.
Old 05-29-2016, 10:10 PM
More pics..
Cleaned it up a bit. Will check differential. <br/>
Old 05-29-2016, 10:25 PM
Should I be able to pull the hub off at this point?
Mark
Old 05-29-2016, 10:30 PM
49fordv8f4's Avatar
Yes, unless one of the bearings has damaged the spindle, then it may come off hard. Otherwise it should pull off easily.
Mark
BTW, Measure the size of the nut before you buy a socket, I was going from memory when I said it was about 3 1/4".
Old 05-30-2016, 12:42 AM
Flat48's Avatar
It's not coming off easy.
I used pullers (pic) and no movement. Maybe I need to go farther but so far nothing.
I removed the nut without socket. It had the chisel notches .
BYW- Thanks very much for you help
Mark
Old 05-30-2016, 06:27 AM
raytasch's Avatar
I would SWAG that when the bearing cage broke, it locked the bearing and the inside race has worn into the housing. Look at the lower side of the housing where the bearing rides. From what I see, I believe you will find a 1/8" groove. If the race has worn much of a groove into the housing, you'll be looking for another rear end.
Old 05-30-2016, 01:02 PM
Finally pulled it off. Doesn't look too bad. But I'm not too sure when it comes to this. It has some pits(pic) but no grove going around.
Hub
Lots of small pits.
Rear end side looks ok.
Old 05-30-2016, 01:14 PM
raytasch's Avatar
Top of the housing looks ok. How about the bottom side, where the pressure would be greatest? Look closely. Does the outside bearing inner race fit on the housing with no excessive play? What does the oil look like that was drained? Water, chunks? Now, inspect the other side.
New inner and outer bearings, races and seals will be on your list, minimum.
Removing axel housing and replacing Mechanicalroofer 1999 to 2016 Super Duty 0 09-09-2014 04:17 PM
1956 F-250 Rear Dana DRW Axel Swap Outlaw56 1948 - 1956 F1, F100 & Larger F-Series Trucks 27 08-07-2013 09:47 AM
Rear end axel for 1999 E350 same as 2002 F350? slk133 1999 - 2003 7.3L Power Stroke Diesel 20 07-14-2012 04:55 PM
2000 F350 single rear Axel swap to Dually Axel Question idesign 1999 to 2016 Super Duty 10 03-18-2011 12:01 PM
2000 F350 4x4 front axel dust seal/shield vonleyser 1999 - 2003 7.3L Power Stroke Diesel 2 01-02-2011 07:16 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
