Starting question
Starting question
My truck usually starts up great, but every so often it takes 3 to 4 long cranks before it will start. By long cranks I mean more than 4 or 5 seconds of turnover. Seems to be no real rhyme or reason to this. It does it engine cold or hot. I have iPhone engine monitor app and numbers seem fine. Just wondering if any of you guys have had this happen and if so what fixed it. BTW it's a 2005. Any advice will be appreciated
DashBoss? The app can be just a touch laggy. Next time you have to crank more than once, watch ICP (500 to start) IPR (not going to 80+%). Also cam/crank sync (Y), FICM sync (Y), FICM main (45+v), FICM (10+v), FICM logic (12v), injector pulse width (more than zero mS), and RPM (160+). You may only see any issue for a split second (if at all) if you're coming off "start" after only 4-5 seconds. It's safe to crank 15sec or more if it's having issues.
FICM logic 12.00
FICM 12.00.
Batt 12.12
IPR 14.69%
ICP 1.71 psi
Cranking... ICP 800+ then back to 650+ at idle. IPR 26.29 FICM 48.50-49. FICM logic 12.50-13. FICM 12.50-13. Batt 13.25-13.50. Any time I'm home the nose is down hill because of how drive way is made. However no problems today. Started right up every time I turned the key.
30 seconds??? That's crazy. No codes. So maybe I'm worried about nothing. But to me that's inconsistent for it to start up almost immediately 90% of the time and then every now and then. Take forever to start.
Not sure I would sweat it. Ours will sometimes fire with authority a split second after hitting the key, other times will crank a few seconds and kind of lope up "I suppose this mean I need to run now" lazy start. I never really worry much about it, just chalk it up to one of those 6.0 things.
Stock cap Motorcraft filter. I did however, put new batteries in it this morning as the old ones were about done for. Guy at the parts store said one batt was only putting out 255 CCA. The other 430CCA. They were supposed to be 750. Thank you guys for all your advice. Hopefully this fixes it. We'll see
HokieHiVPI
05-04-2020 01:36 PM
