F350 Advice?
F350 Advice?
I am a brand new member to this forum. I deeply apoligize if I am violating any rules by posting these questions. Less than a month ago I purchased a 2002 F350 XLT SuperCab that had 250,000 miles on it. I paid under 5k for it. However, a few days ago it blew a head gasket. It also blew a spark plug and took the threads with it. So at this point. I was hoping to get some opinions on where I should go from here? The trans is still in good shape and the interior of the truck is nearly mint. I assume it would be better to sell the truck at a loss and get another one? I assume that getting a rebuilt engine installed would not be worth it due to the cost (I was quoted between 4-5 with labor)? Thank you!
Thanks for the reply. I looked the value up and it seems that in the current broken state, I would be lucky to get $2500. If it was working, it seems like it is worth aroumd 5k. So it is almost a wash. It seems that if I were to get a rem engine installed that it would still hurt the value. It almost seems that trucks with rem engines are worth less money than the same comparable truck with the factory engine. Does that soumd correct?
I guess it depends on what you're intentions for the truck were when you bought it. If your plan was to keep the truck long term, then I would just fix it and continue owning and driving it like you planned. Does it have the right configuration/cab type you were looking for (crew cab vs extended vs regular, long bed vs short bed, 2x4 vs 4x4)?
How great of shape is the rest of the mechanicals on the truck? We're still talking a 15 model year old truck here. Does this thing need to be totally fail safe reliable, or are you able to afford other repairs as they come up? Unless there's been a regular service/repair schedule in this truck's past, you've got a bunch of stuff that will need attention soon. Transmission, diff's/axles, transfer case, brakes, suspension, steering, electrical, charging sys... All of this is 15 years old with a quarter million miles on it.
At least when you fix each part, you know going forward that now "that part" is now good again. If you simply sell this truck and start over again with another 250k mile truck, you start all over again with the unknown.
There's really no wrong answer either way you go, but if this truck's body, paint and interior is in really great condition, you may as well just keep this one as a base starter truck and repair it as it comes.
I purchased the truck from a dealership. Based upon the Carfax report. It was used as a commercial truck in NY (one owner). From the time I purchased the truck to when the head gasket blew, I had driven it less than 40 miles. The dashboard engine light was on when I purchased it. I figured the light was on because it was due for an oil change. I had the oil changed as well as the filters. However, that did not fix the problem. I had the oil change place due a computer read on the truck. They stated that it was a sensor or a cylinder miss fire, both of which were not a huge deal. They said I could keep driving it for the next few weeks until I could get it looked at. Due to family and work, I wasn't able to get it looked at immediately (especially since they said it was not a big issue). On my way to take it to the mechanic to finally get it checked out. The engine made a loud boom and then started making a loud ticking noise. I got it to the mechanic and they told me I had blown a spark plug and head gasket (They quoted $3200.00 to fix). The strange thing is that the engine never overheated or smoked. I always thought your engine had to get very hot before a headgasket could blow?
I am honestly not sure about the rest of the mechanical portions of the truck. However, in regard to the body, it has a some large dents on the outside walls of the bed and some rust around the wheel wells. The interior of the truck is in wonderful condition and so is the exterior of the cab minus some minor rust forming at the bottom of the doors (I think that is common).If I could get it fixed a lot cheaper than $4-5k I would really like to keep it. I haven't had it long but hate to let it go so quickly being that it is my first truck.
I am also confused because I have been told so many different things regarding price and difficulty level of replacing the head gaskets. Some people say it is a $1000 fix. However, all four mechanics I called told me that it would be around $3k and that it would be better to simply replace the engine?
Once again, the engine never overheated (I always watch the gauges), it had plenty of coolant. The radiator is not leaking water as far as I can tell. The truck drove home ok but jerked a little and kept making that loud clicking and raspy sound. I assume that I should get it towed to another mechanic and that driving it any more could cause further damage?
if you are NOT loosing anti-freeze.. and oil is not blowing out the block or exhaust...
Drive it there.. keep under 50...
a head gasket job including machining the heads flat.. is 1500 TOPs ...my opinion.
reasons for the High price..
they do not want to do the job
they do not want to deal with possible valve seals, exhaust system issues.
to much time to do the job. .. they are busy doing easy money jobs.
again my opinion.. retired mechanic. Not Ford... the other guy's.
call around. get quotes. even the ONE or two bay repair shops..... but allow extra time for them to complete the job.
a blown head gasket.. get a compression test..
a gasket can fail ... one cylinder to another
or cylinder to water jacket
or cylinder to oil passage.
or cylinder to outside world..
or a Cracked Head....
I still think the spark plug popped out.. and that was it.. get a compression test and if OK,, get the threads fixed for the spark plug.
No, I didn't get a 30 day warranty. In fact, when I called the dealership. The GM blamed me for buying the truck and said that I should have known that the truck was on its last leg...... I couldn't believe his response since they claim to care so much about there reputation. Not that I am naïve, but I didn't expect such an aggressive tone from such a high end dealership.....
