Auto headlights
If your automatic headlights don’t respond to changing lighting conditions, then the ambient light sensor may be the source of the problem. The sensor can stop working or become faulty if moisture gets into it or fluid is spilled on it. The wiring to the sensor can also wear out. Often, sensor failure results in the headlights remaining on all the time, even in broad daylight.
Simple solution:
Do what millions of drivers have done for over a hundred years...... Since you indicate that the normal on/off functions are working correctly, Turn your own damn headlights on and off as needed. Seriously, "auto" headlights have got to be one of the dumbest automotive "features" ever invented. Just one more thing to go wrong, in exchange for being relieved of the incredibly taxing task of deciding when to turn on/off ones headlights, and then executing that "complicated" decision by turning an easily accessible ****......
Simple solution: Do what millions of drivers have done for over a hundred years...... Since you indicate that the normal on/off functions are working correctly, Turn your own damn headlights on and off as needed. Seriously, "auto" headlights have got to be one of the dumbest automotive "features" ever invented. Just one more thing to go wrong, in exchange for being relieved of the incredibly taxing task of deciding when to turn on/off ones headlights, and then executing that "complicated" decision by turning an easily accessible ****......
I agree with you, but it's also true he paid for this jiggery-pokery, and he wants it to work as advertised. I can understand that. It's also a challenge, and that's kinda fun too. After a while it becomes ... personal.
Sensor on my truck failed too. Bugs me since it's the only defective thing on the truck. Never did figure out the correct part # for the sensor so for the last year I've switched it manually.
And now I shall gripe; on the older auto headlight systems (my 93 Aerostar) the headlights go on and off depending on ambient light. On the 2002 F350 the lights go on, but not off. So when at a stop light under a bridge they turn on, but when the light turns green and I'm again under a cascade of golden CA sunbolts the stupid lights stay on. Wassup wid dat?
Simple solution:
I put a piece of tape over my light sensor. Since ford did not make Daytime running lights (DRL) a standard item, unlike GM, I like the fact I can turn my lights on and when I get done and just turn off the key they will turn themselves off automatically.
On my 3 hyundai elantra, 2001,05,06 when you turn the key off the light will turn off as well. Since my kids drive these cars I tell them to just turn the headlight on and leave them on all the time cause when they turn the car off and get out all the lights. That makes for a safer car, safer kids etc.
I wish all manf would make DRL standard on all cars. I know on my 1997 astro van, which has DRL yes a 1997, I know for a fact that having my lights on have prevented folks from pulling out in front of me. I have seen it many times.
In canada its been that way for years and they can prove DRL do help prevent wrecks. Too bad US is so behind the times..
Stroker, my '02 F250 has been doing the same thing for a couple of years now, research said the sensor on the dash probably is the culprit.
So, like others here, I just turn them on/off manually or drive 'lights on for safety' (most of the time) and don't worry about it.
Have a great day !!
Have a great day !!
Simple solution:
