2000 F350 Dash Removal - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-15-2003, 09:59 PM
lilputt lilputt is offline
lilputt is starting off with a positive reputation.
Question 2000 F350 Dash Removal
How do I remove the dash panel of our 2000 F350? The climate control cluster needs to be replaced after 270,000 miles.....
Old 08-16-2003, 03:18 AM
JJz400's Avatar
JJz400 JJz400 is offline
JJz400 is starting off with a positive reputation.
I'm not sure but I think it is just cliped and should pop out. That is what I found on My 99 when I was checking the lights.
WOW 270,000 thats great. Have you had to do anything to it other than change oil and put fuel in it?
Old 08-16-2003, 07:09 PM
MarkF250's Avatar
MarkF250 MarkF250 is offline
MarkF250 is starting off with a positive reputation.
1. remove radio
2. loosen (2) 9/32 screws underneath the top part of the dash
where the radio was.
3. pull firmly on dash panel to remove.
4. remove ESOF/power point and any other electrical plugs from
dash panel.
you should have access to a/c panel fairly easy now.
Installing a newer dash in a 2000 f650 Jckcont Large Truck 6 12-07-2016 10:05 PM
2009 F350 Dash Panel Removal avvidclif 1999 to 2016 Super Duty 1 06-30-2016 11:21 PM
left side dash panel mark_k 1999 to 2016 Super Duty 0 02-19-2016 02:31 AM
instrument clusters richieschlitt 1999 to 2016 Super Duty 18 02-01-2014 07:26 PM
dash light bulb replacment jpoeta628 1999 to 2016 Super Duty 6 03-07-2008 09:12 PM
Tags
2000, dash, dashboard, dissassembly, duty, f350, f350s, ford, grills, radio, radioremovalin2000f350, removal, remove, removing, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
