Replacing ZF5 4WD Tailhousing: Gas and Diesel the Same?
on
The bore depth for the shift shaft to slide in differs between the -42 and -47, as well as the shaft itself. There is a deep and shallow bore, on the -42 the deep one is in the front case half, the -47 it is in the rear. You can run a -42 front with a -47 rear, but not the other way around.
Also, changing the tail housing requires a complete disassembly of the trans, it doesn't just bolt on the back end.
I found this doing a Google search.
Introduced in 1998 for the 1999 model, the Ford Super Duty was for the first time cosmetically and mechanically unique from the F-150. The first generation of the Ford Super Duty would run from 1999-2007 with a redesign signaling a second generation in 2008 that would run only until 2010.
Then here is Wiki on the total story.
https://en.wikipedia.org/wiki/Ford_Super_Duty
Charlie
Charlie
Charlie
Charlie
https://www.ford-trucks.com/forums/1...uper-duty.html
The following users liked this post:
Received 3,102 Likes
on
F-SuperDuty was 1987 to 1997 with some 1998's thrown in to muddy the waters(there were no model year 1998 F350 or F-SuperDuties made, but some 97's were titled as 98's)
the F-SuperDuty used a 4 wheel drive trans with a trans mount parking brake instead of a transfer case mount tailshaft.
Scott
mdh1701
15
03-19-2017 09:41 AM
delorie65
11-06-2006 08:24 AM
