Starting without transmission?
I bought salvage vehicle with the trans already removed. The engine was supposed to be good but I want to verify. Since the starter mounts to the bellhousing, how can I start it? Is there a trans for the 4.6 that has a removable bellhousing? Or maybe the separator plate between the block and trans is strong enough to hold the starter if I use short bolts and tighten it against the block? Anyone ever try this?
BruteFord
01-02-2014 01:02 AM
Yougotthehit
01-25-2013 01:47 PM
austin2466
03-17-2010 01:57 AM
71F250camper
07-27-2005 02:15 AM
