Drivers side lock button will not lock the door, only unlocks… Other switches work fine
I had a 08 F150 with a similar problem but was the window control switch that was intermittent . I disassembled the switch pack ( not to hard to do) and found carbon build up between the contacts . I used rubbing alcohol and fine emory cloth to clean , then applied a small dab of dielectric grease to the contact points .
No more problems .
No more problems .
Swapped the switch wit the pass side... Switch works great... Not the switch.
